Suspension tips for a CJ7 - JeepForum.com
post #1 of 14 Old 09-27-2011, 11:52 PM Thread Starter
DGRobles
Hi, please I need your advice,
I recently restored a CJ7 '86 and part of the upgrades was the suspension, I installed a RoughCountry 2.5 lift to fit 33 BFG MTs. Te problem I am having is that the suspension is way to hard and on the road the Jeep is waaay too bumpy.
I used to have previous to this CJ-7 a '05 Wrangler X with OME 2.5 springs and shock, I know it's "impossible" to have the same ride and feeling as a TJ on the CJ-7 but, is there any way to make the ride more comfortable in this way?...
Regarding the shock absorber, there no specific brand (Monroe) and I think more street use...and well, tires are 33" R16 running at 33 PSI
Any advice is more than welcome"
Here is a Photo of my new toy
Diego Robles / XE1XZQ
DGRobles is offline
post #2 of 14 Old 09-28-2011, 07:36 AM
rdsk8ter
1982 CJ7
shackle reversal made a HUGE difference on mine rides like a caddy in comparison to how it did
rdsk8ter is offline
post #3 of 14 Old 09-28-2011, 07:39 AM
82KansasCJ
82KansasCJ's Avatar
1982 CJ7
Nice looking Jeep! You might try running less pressure in the tires. I only run about 20psi in my 35's and it was a huge difference vs the 35psi I was running. I also think that if you do a search you will find the Rough Country springs are considered pretty stiff compared to others.
1982 CJ-7....not perfect but still alot of fun!
82KansasCJ is offline
post #4 of 14 Old 09-28-2011, 09:25 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The 2.5" OME YJ springs and OME shocks sure smoothed the ride of mine over the worn out stock suspension.
Here's my install thread:
http://www.jeepforum.com/forum/f8/ol...stall-1245523/
Adding a little more weight to your rig may also help. I noticed mine was less "jumpy" when I put the hard top and a heavy Warn winch back on her.
Matt
Matt1981CJ7 is online now
post #5 of 14 Old 09-28-2011, 10:15 AM
Renegade82
1982 CJ7
Rough Country is just simply a stiff spring. I don't think your going to change that much. I've had them on for 12 years now and their still stiff.
Renegade82 is offline
post #6 of 14 Old 09-28-2011, 10:26 AM
andy_mitch92
1977 CJ7
35psi makes my jeep ride like crap on rough roads. I run about 25 and it rides pretty nice.
Also check to be sure you didn't over tighten your shackle bolts.
Sent from Droid X2
andy_mitch92 is offline
post #7 of 14 Old 09-28-2011, 01:24 PM
WoodyHD
1983 CJ7
Something about your jeep I really like. RC makes stiff springs, and that's that. You could also check your shackles. If they're tightened too much they'll limit the movement of the spring.
WoodyHD is offline
post #8 of 14 Old 09-28-2011, 02:35 PM
aggiejon
1979 CJ7
A question for the CJ experts out there...In this picture are steps to get into the jeep. I just picked up a heep for parts and it had these steps. The guy selling it said that they were Laredo package side steps and were apparently worth saving? Anyone know?
aggiejon is offline
post #9 of 14 Old 09-28-2011, 04:46 PM
SleeperCJ
1983 CJ7
They are Laredo side steps. I used to have them but kept smashing them on rocks and eventually took them off. If you don't want them, there are plenty of people out there looking for them. Not sure how much they are worth, but no need to throw away perfectly good parts.
SleeperCJ is offline
post #10 of 14 Old 09-28-2011, 07:50 PM
aggiejon
1979 CJ7
I salvage all I can. I know some must die so others can live, but I also can't see scrapping perfectly good parts.
Well if anyone has any more insight let me know. I'm sure I'll let the ultimate capitalistic society of eBay dictate their value.
aggiejon is offline
post #11 of 14 Old 09-28-2011, 07:57 PM
shull360CJ7
Did only Laredos have those steps? Wonder if it was also a factory upgrade. Mine had them, still laying in the garage after YJ tub swap.
'98 Sport, 5 Speed. Green Emerald Metallic. Bestop soft top.
BDS 2" lift, AR steel wheels, 31"x10.5" Goodyears. Stock axles, stock 3.07 gears.
Immigrant from the CJ world...be patient...I can be taught
shull360CJ7 is offline
post #12 of 14 Old 09-28-2011, 08:10 PM
BagusJeep
1981 CJ7
There were Running Boards and there were Steps. The Steps have two styles, diamond and smooth. They were fitted to Laredos but you coud have them dealer installed on any model.
With the proliferation of side mouldings after market there are better solutions to how your lady friends get into a CJ with modesty intact. Mine is a push up or a pull in.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #13 of 14 Old 09-29-2011, 08:06 AM
nyolles
I just sold a pair of those steps. They're highly sought after. A pair just sold on eBay for $160.
nyolles is offline
post #14 of 14 Old 09-29-2011, 01:34 PM
OKRenegade
I like the combination of the step and front fender flare, like that they keep a similar line.
OKRenegade is offline
Howell TBI tips stroh Jeep CJ Forum 14 04-21-2011 09:32 PM
Ressurecting a 76 CJ, tips? Foundrydude Jeep CJ Forum 12 01-07-2011 09:37 AM
Need tips. Putting LT1 in 79 cj7. bz79jeepcj Jeep CJ Forum 1 04-20-2009 07:17 AM
any tips for shift kit? madjp62 Jeep CJ Forum 6 06-26-2006 12:39 AM
Top Tips Tuts Jeep CJ Forum 5 09-25-2002 09:34 AM
