Suspension Lift - JeepForum.com
post #1 of 5 Old 03-19-2002, 12:21 PM Thread Starter
mikeythefireman
mikeythefireman's Avatar
Post Suspension Lift
I am looking at getting a 83 CJ7 cheap. Downside is it has almost 10 inches of lift with 3 inches of body lift. What are all the parts I would need to lift a stock CJ7 4". I don't want a shop to screw me over with parts I don't need, but I don't want to jury rig anything. I have to bring this jeep down, but I don't want to get ripped off. Please HELP!!
Just Sayin'
mikeythefireman is offline
post #2 of 5 Old 03-19-2002, 02:58 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Post
Well, all you need to do is put in stock body mounts, and buy a 4" suspension lift kit, which should include 4 new springs, u-bolts, shocks, poly bushings, dropped pitman arm, and I would put stock height or 3/8" "overlength" heavy duty shackles, like ConFerr. I prefer Skyjacker for the lift kit, as it is very high quality and offers a smooth ride.
4wheeler4CJ is offline
post #3 of 5 Old 03-19-2002, 05:34 PM
Bulletproofcj7
Post
First of all get rid of the 3" body lift, that should bring you down to 7" if i understand you right. Next find out how it is lifted. to my knowledge there are no 7" lift kits made, it may be a combination of a 2 1/2" springs and a SOA conversion or something involving huge shackles. whatever the case, you should be able to remove a portion of the lift to get it down from the clouds. If you came to that 10" by measuring from the ground to the bumper and comparing it to a stock jeep then dont forget to take into account the larger tires.
Anyway it sounds like you may have everything you need for parts, just too much of it, exept for the correct length shocks.
If it is some huge homegrown set of stilts then you may be better off scrapping it and buying a kit. I have a sky jacker softride that came with shocks for around $400.-$500.that works nice and is easy to install.
just my .02 cents
jason
Another crazy bastard who runs into a fire when everone else is running out!
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #4 of 5 Old 03-19-2002, 05:36 PM
SamFromCO
SamFromCO's Avatar
Post
If it has 3" body lift that means it has 7" of suspension lift. Sounds like it could be a spring over lift. Are the axles mounted underneath the springs?
'86 CJ7, 258 w/Mopar MPI, 4.56 gears, rear Detroit/front Truetrac, full cage, OBA, 8274, 4" lift via Alcans/Rancho, 35's on beadlocks, other stuff. Built for rocks, mud is a four letter word.
SamFromCO is offline
post #5 of 5 Old 03-19-2002, 09:58 PM Thread Starter
mikeythefireman
Post
I will post the pics tomorrow for everyone to take a shot at advice. I don't remember about the SOA, I haven't seen the Jeep in a while. We'll see. Thanks for all the advice.
Just Sayin'
SOA or Suspension Lift? breakthru Jeep CJ Forum 10 09-03-2009 09:00 PM
YJ suspension lift kit on a CJ7? westtexascj7 Jeep CJ Forum 6 07-26-2009 10:51 AM
suspension lift 78GoldenEagle Jeep CJ Forum 13 05-08-2008 03:31 PM
Would someone please explain the difference between a suspension lift and a body lift Giff Jeep CJ Forum 5 09-20-2007 04:49 AM
Body lift vs. Suspension Lift jmreagan Jeep CJ Forum 4 02-10-2006 03:49 PM
