Super's 258/4.0 conversion build - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Super's 258/4.0 conversion build
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 06-09-2013, 05:22 PM   #16
abthis01
1980 CJ7
I did pretty much same build on my '80 CJ...except went with Clifford intake and matching header with a Holley 2 barrel & HEI distributor. LOVE IT...I have been driving it everyday for over a year, sometimes 100miles in a day running 60 to 70mph rolling on 36"s with no problems at all...you will def be happy! Also I put in new radiator with electric fan just to make sure, runs cool all the time even pulling a trailer with a atv on it...
-1980 CJ7- Sometimes Called a Heep depends on what breaks that day -
abthis01 is offline   Reply With Quote Quick reply to this message
Unread 06-13-2013, 08:44 AM   #17
supersport126
Got some more done, had to really modify the power steering bracket to clear my header.
supersport126 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2013, 03:20 PM   #18
BadHabit80cj7
1980 CJ7
There's an adapter that goes between your skid and tranny on the auto's that your missing.
http://www.jeepforum.com/forum/f8/t-...ssues-1534167/
BadHabit80cj7 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2013, 04:00 PM   #19
supersport126
Yea that's my thread you linked, but thanks!
Unread 06-22-2013, 11:15 PM   #20
supersport126
transfer case is in, rebuild cost was 175.00. They said it didn't anything but seals and gaskets and looked good inside. got it in tonight, doing all this solo is kicking my ***. I struggled getting that sucker in and had to let it go once. new drive shafts for sure, but we all knew that. I was at least hoping the rear would bolt up enough to drive it up to the exhaust shop.
Unread 06-28-2013, 03:52 PM   #21
supersport126
Just got my driveshaft back from arrow truck in Detroit they had to cut it down from 24.25 to 21.5. 38 bucks out the door! Yeah!!!
Unread 06-30-2013, 01:34 PM   #22
supersport126
Unread 07-14-2013, 05:19 PM   #23
supersport126
Ready to start it
Unread 07-14-2013, 05:43 PM   #24
swatson454
swatson454's Avatar
1983 CJ7
Very cool. I'm diggin' your Jeep
You might see if you can get the bypass on your filter pointed slightly uphill, too. Make sure it's a 12 o'clock. Can't wait to hear it.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2013, 05:57 PM   #25
supersport126
Shawn
Nice catch, I'll do that for sure. I planned on cutting the metal back a bit anyway and get rid of the last bend
Unread 07-14-2013, 06:10 PM   #26
VACJ7
Hockey Rules!
VACJ7's Avatar
This is what the auto trans mount looks like. The "M" bracket and torque plate. Under that plate is the rubber mount. Large hole on the left side is for the torque arm. Finding those steel brackets may be challenging.
Paul
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 07:59 AM   #27
supersport126
Got jeep running, break in last week. This week has been getting the trans shifting right. I installed a Lokar kick down cable and still getting shift points adjusted. I haven't really updated this post on time but it didn't show much interest. Video to follow of engine running soon
Unread 08-23-2013, 05:59 PM   #28
supersport126
Unread 08-23-2013, 06:16 PM   #29
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Nice looking setup.
My only critique is your modified fuel line. The reason for the steel line from the pump, running over the top of the valve cover, is to prevent heat from rupturing the rubber fuel line. I'd be leery of your setup.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 08-23-2013, 06:50 PM   #30
supersport126
Originally Posted by Matt1981CJ7
Nice looking setup.
Matt
Thanks for looking, I'll keep an eye on the lines
