Superior Axle Install Question - JeepForum.com
post #1 of 7 Old 01-03-2002, 08:36 PM Thread Starter
diamatron
1978 CJ7
Post Superior Axle Install Question
We started installing the model 20 rear One Piece Axle Kit tonight.
Problem is getting the gap tolerance from the Timken bearing to axle correct.
We believe everything is correctly in place on both sides we still have .12 protrusion. Which Superior says should be between .02 and .06"
Therefore having to get the Spacer Machined .08 to hit the optimum figure.
Anyone else run into these Problems?
RICK
diamatron is offline
post #2 of 7 Old 01-04-2002, 07:43 AM
Crash&Burn
Post
Is there a way to call Superior and ask them?
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust
I'm not as good as I once was....but I'm good once as I ever was.
Crash&Burn is offline
post #3 of 7 Old 01-04-2002, 07:56 AM Thread Starter
diamatron
1978 CJ7
Post
Yes. They tell me to Either Shim the Axle or grind the spacer shorter. But, worried that I have the inner seal properly seated because 98% of there customers never have this as an issue.
Thing is. At first install I was not going to change the inner seal, becaue they were in grear condition. But, after instll I had too large of protrusion. Thinking maybe the supplied inner seal was thinner I decided to install theres from the kkit. So, I had the same number with the seal I instalkled and the original seal. Makingme think I have the install correctly.
post #4 of 7 Old 01-04-2002, 10:35 AM
only in a jeep cj
Post
I too did this install on a buddies CJ-7 and found both sides stuck out way too far. I used a block of wood and a hammer to make sure the seals wear seated all the way.....in the end, I spent about 30 min on each spacer using a grinder to machine down the spacers. All went in well from there and it's been several years with no problems....Besides, have you every had an aftermarket part fit 100%, 100% of the time!
ED
86 CJ-7 Laredo
75 CJ-6
82 AMC Eagle Wagon
80 Scout II
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #5 of 7 Old 01-05-2002, 03:54 PM Thread Starter
diamatron
1978 CJ7
Post
We really had to machine the spacer a lot.
First had it machined shorter in length by .08 inches
Then we couldn't get the spacer to install all the way back to the inner shield because there is a lip insode the axle whick was too narrow for the lip on th outer spacer to get through. Thererfore we had to get that lip machined off of the spacer.
I hope everything works out okay in the long run. We have a secure fitting spacer with a protrusion around .04 inches. But, the surface area which the spacer presses to the bearing is cut about in half.
post #6 of 7 Old 01-09-2002, 04:49 PM
only in a jeep cj
Post
Anyone who did this swap have a good ( non spun) drivers wide track axle left over? Thanks
ED
Ed
1975 CJ-6 1983 CJ-8
post #7 of 7 Old 01-14-2002, 06:11 AM
Bulletproofcj7
Post
Has anyone just welded the flange to the axle on the stock splined axle before they break? just curios if would be worth it?
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
Superior Axle Install gdepley Jeep CJ Forum 2 01-28-2009 03:07 PM
need help with a superior 1 pc. axle CJ7191959 Jeep CJ Forum 1 09-06-2008 06:50 AM
superior axle 20 vs dana 44 gregsteele1979 Jeep CJ Forum 4 02-11-2007 08:39 PM
Superior Axle Question? jettro Jeep CJ Forum 2 05-09-2005 12:28 AM
superior one piece install Curly Jeep CJ Forum 1 04-12-2003 07:34 PM
