Superior 1 piece axles bearing kit unavailable. - JeepForum.com
post #1 of 15 Old 06-06-2013, 04:44 PM Thread Starter
rays84cj7
Hello I went to order a bearing kit,Superior part# EV20KIT, for my superior 1 piece axles on my Amc20 axle and it appears they are unavailable. It looks like superior went out of business. I tried the phone number on the website and I just get a constant busy signal. I also went by the address on the website since I was in the area anyways. There is a new business at this site and the man working there said superior used to be there.
What are my options now. I just have the bare axle shafts and empty axle housing ends. I cut the old bearings off the shafts. The kit was supposed to have an inner seal, outer seal, retainer ring, bearing, and a spacer. Im not sure what bearings, spacers, and retainers will work. I guess worst case, I could buy another set of axle shafts. thanks Ray
rays84cj7 is offline
post #2 of 15 Old 06-06-2013, 09:28 PM
S76
Ouch, that's not good.
Don't get nervous though. All of the parts you need are common parts. I'm sure the bearings, the seals and all can be bought at a bearing supplier.
The hard part is figuring what the right numbers are. If you can get a part number off one of the bearings it can be cross referenced.
Try Googlin. You'd be surprised what you can come up with.
If you always do what you've always done. You will always get what you've always got.
S76 is offline
post #3 of 15 Old 06-06-2013, 09:30 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
If they're timken bearings, someone will stock them.
Luck Favours The Prepared
Anticanman is offline
post #4 of 15 Old 06-06-2013, 09:36 PM
WindKnot
1977 CJ7
Do you have the spacer ring?
I'm pretty sure the bearing set is Timken # 9. The seals are Jeep parts. The part that MAY give you problem is the retainer ring.
I would call Moser and throw yourself on their mercy and ask them flat out if their set will fit Superiors. Who knows
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #5 of 15 Old 06-06-2013, 09:38 PM Thread Starter
rays84cj7
I dont have any of the parts. I took it apart over a year ago.
post #6 of 15 Old 06-06-2013, 09:39 PM Thread Starter
rays84cj7
I know I can get the seals no problem
post #7 of 15 Old 06-07-2013, 06:36 AM
wm69
Tag for part numbers. I have a set of Superior 1 piece axles in the shop that came (uninstalled) on an extra AMC20 I bought. I was going to put them in when I install a truetrac in the rear of the green Jeep, and needed the bearings/seals. Only thing I have is the shafts and the retainer plates.
Pirate and an Xterra forum both saying the same thing; Superior fell off the face of the earth.
wm69 is offline
post #8 of 15 Old 06-07-2013, 04:59 PM
skizriz
1978 CJ7
Wow. I recently bought one piece axles. I couldn't decide on Superior or Moser.
Glad I chose Moser.
skizriz is offline
post #9 of 15 Old 06-07-2013, 07:08 PM Thread Starter
rays84cj7
Ok I found the old spacers that go inside the axle next to the inner seals. Now I think I only need to worry about the bearing retainers. From what I've read, The bearing retainer for the superior axle shaft is a machine down version of what comes with Timken Set 9 Bearings. According to this thread: http://www.jeepforum.com/forum/f8/su...-needed-741713 The width of the rings are .375", the OD is 1.938, and ID is 1.370. Hopefully I can take the rings that come with Set 9's to a machine shop and have them machined down. Another post says (NOT inside diameter, or outside diameter, but thickness to 0.300" thick, about half of factory Timken Set 9 thickness)
I think there's alot of Superior 1 piece axles out there, so im sure this is going to be an issue for many. I would be interested to know if the Moser retainer and spacer would work. This axle has been sitting in my garage for a long time. I wasnt in a hurry to order the bearing kit because I figured Superior has been around a long time and wasnt going anywhere. Wrong!! It weird that their website is still up.
post #10 of 15 Old 06-07-2013, 10:47 PM
Jacoby22
1983 CJ7
Jacoby22 is offline
post #11 of 15 Old 06-08-2013, 08:23 AM
Jacoby22
1983 CJ7
http://mudflaps.com/i-8380566-superi...FfA7Mgodz0EASw
There's 2 available here so you can do both sides. Hope that helps.
Jacoby22 is offline
post #12 of 15 Old 06-08-2013, 08:30 AM
sherlocktk
After I hand grenaded my one piece bearing I bought this kit comes with everything you need. With a genuine timken bearing. Spacer etc all looked to be the same size as the superior one. It's the replacement bearing and seal kit for a crown one piece axle
http://www.quadratec.com/products/52401_100.htm
sherlocktk is offline
post #13 of 15 Old 06-08-2013, 02:31 PM
WindKnot
1977 CJ7
^^^And this specifically fit your SUPERIOR axle?^^^ That would be wonderful news.
WindKnot is offline
post #14 of 15 Old 06-08-2013, 04:06 PM
sherlocktk
Yes this specifically fit the superior axle. Used the 2 seals, spacer, bearing, and bearing retainer (machined one that was 1/2 as thick as what comes with the set 9). Did not use the studs as mine were still fine but they looked to be the same. I guess the knockoff's are good for something
post #15 of 15 Old 06-09-2013, 03:48 PM Thread Starter
rays84cj7
Thank you Thank you!!! Just ordered 2
