Summit CDI install on a 79 CJ5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Summit CDI install on a 79 CJ5
Spartan Locker's at all time LOW exclusive from ROCKRIDGE FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Bds fox ipf 2.0 racing series shocks now available at rock
Unread Yesterday, 09:49 PM   #1
herpman
1979 CJ5
Just bought this off of ebay. The old style Summit CDI suggested on this forum by "JEEPHAMMER". I am pretty limited when it comes to wiring and need someone to spell out for me where to connect the wire that should connect to the ignition switch as shown in the picture. Everything is stock except for the "team rush" upgrade. It's the inline 6 motor. _57.jpg
herpman is offline   Reply With Quote Quick reply to this message
Unread Today, 12:54 AM   #2
BagusJeep
BagusJeep's Avatar
1981 CJ7
The red wire at the top should connect to the red with tracer wire that goes to the existing coil positive. This wire serves a number of items under the hood and is live in run and Start only. The thing to watch is that you connect BEFORE any resistor wire you have in there, in other words you connect to 12V and not 7V. If you have an electric choke wire it will be red with tracer and be in the loom before the resistor.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1947 Willys CJ2A/3A/MB/M38 - Little Willy
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread Today, 03:52 AM   #3
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Use the big red with white tracer wire between the firewall and old module.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread Today, 07:47 AM   #4
herpman
1979 CJ5
No start. . . here's what I have. I tried hooking up the red wire to the old + coil wire (no start). So I tried cleaning it up. I took the old coil + back to the wiring loom and found the splice. Removed the splice and cleaned up the connection to the starter solenoid. Then routed the red wire to the starter solenoid and hooked into the smaller positive post (checked for 12v source with key on). I bought the MSD part#8869 adapter for between the module and the distributor. Black and Red are ran to correct battery terminals, orange is going to coil positive and black(smaller) is going to coil negative. Yellow is hooked to my tach, and white is capped off with a wire nut. I have the module set for 6 cylinder by having switch 2 down and switch 3 up (1 and 4 are still down). And I have the rev limiter set to 0 (4500 RPMS). Still .. . no start.
Unread Today, 08:55 AM   #5
herpman
1979 CJ5
I think I have it figured out. . .I think switch #1 needs to be up (see figure 2 on the top of page 3). http://static.summitracing.com/globa...sum-850600.pdf It says "ON" next to the #1 switch. . .
Unread Today, 10:44 AM   #6
herpman
1979 CJ5
. . . still wrong. . .switch #1 is just tied to the RMP limiter
Unread Today, 10:45 AM   #7
herpman
1979 CJ5
Does anything need done to the old coil - ( I have it hanging out in the breeze right now)?
Unread Today, 11:13 AM   #8
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Your old coil wire only has 9 volts or so when running because it uses a ballast wire. Like everyone else says, you need the red wire with the white trace that goes to the old ignition module for 14 volts.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread Today, 02:33 PM   #9
herpman
1979 CJ5
So even with the coil splice removed and hooking into the wire the coil + was spliced into? I followed it through the loom and it looks like it all ties into the red w/ white tracer your talking about.
Unread Today, 04:53 PM   #10
herpman
1979 CJ5
Still no fire. . . Cut the red with white tracer wire going to my old module and hooked it up to the new using the little red wire. Checked and rechecked all my connections. Rechecked that I had the box set for 6 cylinder. Nothing. . .
