Suggestions on '63 CJ-5? - JeepForum.com
post #1 of 2 Old 04-24-2013, 06:46 PM Thread Starter
mreagan
1963 CJ5
Hey fellow Jeepers, I just bought a 1963 Willy's and it's in pretty good shape. I Have always been ok with mechanics, but I'm stumped on this one.. I drove it around for about a week, and then it just quit going. When I put it in gear and let the clutch out, it just makes a weak sort of grinding sound. It sounds like it is coming from the bell housing? I have checked all my linkage and everything seems to work fine, there is a pto driven winch on the front, and I made sure it was disengaged. Could it be the clutch? If so, do I have to pull the engine or drop the tranny to get to it? I have a V6 engine and a three speed transmission with a high/low splitter lever and a transfer case lever and low and high 4x4 lever, so there are four shift levers coming through the pan. I've had the top end of the transmission open from inside and everything looks good, plenty of gear oil in everything including the differentials. I'm just not sure on this one. Any help?
mreagan is offline
post #2 of 2 Old 04-24-2013, 07:07 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The first thing to check is to insure you didn't accidentally pop the t case or the overdrive into neutral.
If that is good, With the trans IN GEAR and the cover off, SLOWLY release the clutch and observe the output shaft (push it back on as soon as things start turning, or you will be wearing some 90WT, or you can drain it if you like). If the input shaft doesn't turn, you have an issue with the clutch. If it does turn, but the mainshaft doesn't, you have a problem with the input shaft, or the countershaft. If the output shaft turns, then....
Drop the inspection cover on the t case and let it drain. Reinstall the transmission cover and put it in gear. Have somebody slowly release the clutch while you observe to see if the transfer case gears are rotating. If not, you will probably have an issue with the planatary's in the O/D unit. This is not an uncommon issue and will require removing the O/D unit.
Don't forget that the boxes will be empty. You may want to pull a battery cable or incapacitate it to keep from accidentally driving it.
jeepdaddy2000 is offline
