Suddenly low oil pressure - JeepForum.com
post #1 of 10 Old 02-18-2013, 02:18 PM Thread Starter
stripperguy
Here's the story--
Only about 20k miles on my 10 year old full 258 rebuild.
Always had great oil pressure, hot or cold, idle or 2,000 rpm.
Then I noticed that my hot idling oil pressure would drop to nearly zero, and the engine would run rough too. If I rev it up some, the oil pressure is mostly back to normal, and the engine smooths out too!
Background:
Comp cam 252 I think, with matching hyd lifters
high volume oil pump
calibrated mechanical oil pressure gage
Weber 38/38
Clifford intake, Hedman hedders
New (20k ago) main bearings, rod bearings, cam bearings, new 20 over pistons and rings.
My S-I_L mechanic is thinking I could have collapsed lifters...what do you guys think??
1977 CJ5 is a CJ build ever really done?
2002 TJ gone
2005 TJ also gone
2005 LJ insurance wreck
stripperguy is online now
post #2 of 10 Old 02-18-2013, 09:39 PM
Double8racer
although mechanical gauges are rather reliable have you tried another gauge and inspected the existing line for any possible leaks.
Double8racer is offline
post #3 of 10 Old 02-18-2013, 09:59 PM
Jeepkid1995
1979 CJ7
Maybe a stupid question, but did you do in oil change in there somewhere and use a different oil weight? I used to have nothing at idle hot or cold, but then I changed the oil to a 15/40 diesel oil, and I get strong oil pressure all through the rpm range. And x2 on a leak in the oil line to gauge
->'79 CJ7 (VIN Says it's a 5, wheelbase says otherwise), 6 inches of spring lift, awaiting an MC2100 on a teamrushed MSD'd 258
-->350 time. '95 block SBC, stroked to 383, dremeled heads and big 'ol intake, maybe a Holley 750 CFM, not sure yet
--->"Safety? Buy a Volvo. Never buy a CJ, or a Chrysler Jeep knock off, for safety, fuel mileage, reliability, handling, ride, comfort, aerodynamics, quietness, convience, stability, low maintenance cost, performance, or ease of use. The only reason to buy a CJ is because you are absolutely, incurably nuts." -OldTexas
Jeepkid1995 is offline
post #4 of 10 Old 02-18-2013, 11:23 PM
BagusJeep
1981 CJ7
You could have leaky lifters, but it is probably your oil. When was the last time you changed it and what did you put in?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 10 Old 02-18-2013, 11:45 PM
86cj74.2L
86cj74.2L's Avatar
Gassed oil comes to mind.
86cj74.2L is offline
post #6 of 10 Old 02-19-2013, 12:45 AM
WSS
WSS's Avatar
1972 CJ5
A double gasket on the filter maybe? I notice in equipment that a wix filter will run lower pressure than a fram often due to more filter volume (less back pressure). Some brands also have a bypass if it gets too clogged.
The running rough suggests somthing like this. If you can get a oil sample done, it will tell you the health of the motor too just to rule out the gassed oil from bad rings or some gremlin in the motor ($$)
WSS
WSS is offline
post #7 of 10 Old 02-19-2013, 05:15 AM Thread Starter
stripperguy
Thanks, guys.
My first thought was gassed oil...I did an oil and filter change (straight 30 wt) with no benefit.
And I verified my oil pressure gage accuracy and inspected for leaks. I also substituted another mechanical oil pressure gage, the low idle pressure is definitely for real.
What puzzles me is the sudden onset of these symptoms, I had 10 years of flawless performance, and then BAM!!
2002 TJ gone
2005 TJ also gone
post #8 of 10 Old 02-19-2013, 07:26 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
I didn't have a sudden drop like that, however the oil pressure at idle was 1-3 psi. With higher revs it would come up, but only to about 18-22 psi max. I installed the Snelling high volume pump, and the low idle pressure didn't move, the top end would come up about 8 psi higher, but it wasn't the fix I was looking for. My next step (wich may be yours as well) is to check and probably replace main bearings.
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #9 of 10 Old 02-19-2013, 07:56 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I think the SIL may be right. Or you have an obstruction, somewhere.
Oil pumps will also fail. Once, I even had a new pump that wouldn't hold air, right out of the box.
Matt
Matt1981CJ7 is online now
post #10 of 10 Old 02-19-2013, 10:08 AM Thread Starter
stripperguy
Matt
I'm still in the middle of a SOA mod...once that's done, I'll dig into the oil pressure mess.
I'm considering a higher performance camshaft, would swap in new lifters at the same time.
Oil pump? You know, I did install a high volume pump back when, but I reused my old pick up tube. That tube is only held in by interference fit...what if it somehow shook loose??!!
I guess I should drop the pan and check out the mains and oil pump...
2002 TJ gone
2005 TJ also gone
