Sudden ignition prob. Need immediate help - Page 2 - JeepForum.com
post #16 of 31 Old 08-24-2013, 11:18 PM
BagusJeep
1981 CJ7
For the MSD 6A (you do not say what you have exactly or how it is wired) you MAY have:
  • ground is a heavy black wire,
  • power is a heavy red wire,
  • switched 12 volts is a thin red wire,
  • the coil positive (+) wire is orange,
  • the coil negative (-) wire is thin black,
  • the signal wires are green and violet.
Apart from the first three wires please check the wire colours match YOUR setup, there are several MSD boxes and several ways to wire them into an ignition system.
If you are not getting 12V on the orange wire you need to check the other wires.
Are you getting 12V on both Red wires and is your ground good on the heavy black wire???
Just having 12V from the switch will not be enough to get the MSD to work, it needs the large red wire to be live as well as a good ground. Like any good electronics the ignition switch is not directly in loop to the coil.
If you do not have voltage on that large red wire you will have to find out how it is fused and what it is connected to. The correct way to wire it is to a circuit that is live in Run and Start, those circuits having Red with tracer wires. If it is wired to a circuit with a solid red wire it will always be live and a drain on the battery.
As suggested best way to check is with a test light. I don't know if the MSD is sensitive to low voltage i.e. dying battery.
It may be unrelated to your battery issues, like buses CJ problems come in fleets and then nothing for ages.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #17 of 31 Old 08-25-2013, 04:49 AM Thread Starter
vinnyabs
1983 CJ7
So woke up early to try again. No success. But did remember that the solenoid has to be mounted to be grounded and work! Did that and the motor actually turned. I didn't hold the key long enough to start I guess bc I wasn't expecting anything different. I tightened everything down and right back to click at solenoid and nothing else. Try a couple of more times checking different locations with a test light and eventually not even a click although test light still lights up. Had to bring wife's car to work today so ill be back at it tonight.
86, no neutral safety. Bagus, I have team rush and nuttered. No extra spaghetti. Just the bare necessities and the msd is exactly as you quoted.
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #18 of 31 Old 08-25-2013, 05:32 AM
86cj74.2L
86cj74.2L's Avatar
The MSD provides the power to the coil and it won't do that I believe until it sees a signal from the distributor pickup.
The little red wire to the MSD has power in the on position?
Do you have power going to the starter solenoid in the start position?
86cj74.2L is offline
post #19 of 31 Old 08-25-2013, 06:24 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Vinny,
Here's the procedure for testing the MSD box....
1. Make sure the ignition switch is in the Off position.
2. Remove the coil wire from the distributor cap and position the terminal so it is approximately 1/2" from a good ground.
3. Disconnect the MSD Magnetic Pickup connector from the distributor.
4. Turn the ignition to the On position. DO NOT CRANK THE ENGINE.
5. With a small jumper wire, short the Green and Violet magnetic pickup wires together then pull the jumper off. Each time the short is removed a spark should jump If spark is present, the ignition is working properly.
If there is no spark:
1. Inspect all of the wiring.
2. Substitute another coil and test again. If there is now spark, the coil is at fault.
3. If there is still no spark, check to make sure there is 12 volts on the small Red wire from the MSD when the key is in the On position. If 12 volts are not present, find another 12 volt source and repeat the test.
4. After inspecting the test procedures and inspecting all of the wiring, there is still no spark, the Ignition is at fault.
I had a similar issue with my new MSD ignition. My engine randomly shut down while driving. The above test showed no spark. The problem ended up being a poorly crimped connector on the large red wire to the battery positive.
Good luck,
Matt
Matt1981CJ7 is offline
post #20 of 31 Old 08-25-2013, 10:35 AM
Mace350
I know everything is clean, just sounds like your losing a ground somewhere. Maybe buy a ground strap kit but just for the hell of it I would take an old wire and ground the solenoid. Especially after reading this.
Mace350 is offline
post #21 of 31 Old 08-25-2013, 11:54 AM
jeepwhore
x2.
After you got it to turn over the first thing I would have done is add a dedicated ground to the solenoid. Or just scratch the paint off the inner fender where it's mounted to ensure a good ground. I had a similar issue and chased the problem through the entire ignition circuit......only to find the solenoid grounded poorly. I no longer trust any sheet metal grounds like the inner fenders!
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #22 of 31 Old 08-25-2013, 07:44 PM Thread Starter
vinnyabs
1983 CJ7
Thanks to all of you for once again coming through in a pinch!! I found the culprit and many of you were right. It was unsuspected. The switch power wire to the msd was showing hot when on. Apparently not hot enough. Changed it from a link into the ignition wiring directly to the solenoid run pole and the end of a hunt!! Apparently my new snorkel hoses were putting a lot of pressure on it where it was and the connection didn't support enough current to power the box!! Just when you think you know something…. Thanks again to all of you. This community is the best!!
vinnyabs is offline
post #23 of 31 Old 08-27-2013, 09:55 PM Thread Starter
vinnyabs
1983 CJ7
I am sorry for the bump. But not really. I have been known to get passionate about my situations. But I wanted my thanks to be repeated. Matt, Shawn, 86, LG, uptillnow, and many more have been more than helpful. I appreciate every bit of advice even if I come across as harsh. It's the Italian and NY in me. What I know is that my baby is running better than some jeeps of the production. Line bc of all of you. Thanks again. Sappy ***** over.
vinnyabs is offline
post #24 of 31 Old 08-27-2013, 10:00 PM
Matt1981CJ7
1981 CJ7
Good news, Vinny!!
And thanks for the kind words.
Matt
post #25 of 31 Old 08-27-2013, 10:05 PM
LumpyGrits
Your welcome
Glad it's run'n.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #26 of 31 Old 08-27-2013, 11:21 PM
86cj74.2L
86cj74.2L's Avatar
Yes your welcome
post #27 of 31 Old 08-27-2013, 11:37 PM
BagusJeep
1981 CJ7
Is that pole live in Stop? The solenoid does not control the power on in Run. The only pole which will be live in Run will be the incoming supply from the battery, in which case the box will always be on and drain the battery.
If that is where it is connected you could insert a relay controlled by the ignition circuit and I would think about a fuse. Alternatively a battery cut off switch and a fuse.
post #28 of 31 Old 08-28-2013, 04:25 AM
Matt1981CJ7
1981 CJ7
Good catch, Bagus. One side of the solenoid is always hot, the other is hot only in the Start position, but not in Run.
I sure hope our buddy Vinny doesn't wake up to a dead battery.
Vinny, what switched power source did you have it connected to before? Was it the big red w/white stripe wire? Did you solder and waterproof the connection?
Matt
post #29 of 31 Old 08-28-2013, 07:41 AM Thread Starter
vinnyabs
1983 CJ7
I attached it to the smaller run pole on the top of the solenoid where the ignition switch connects. Not the large side hot pole. Before I had it spliced into the ignition switch wire along the firewall. It wasn't soldered before bit it is now. I originally was working on too much and too quickly and had said I would come back to it and do it right but this beat me to it.
vinnyabs is offline
post #30 of 31 Old 08-28-2013, 02:32 PM
86cj74.2L
86cj74.2L's Avatar
The old + wire to the original ignition coil is a good wire for the run input to the MSD.
