Sudden ignition prob. Need immediate help - JeepForum.com
post #1 of 31 Old 08-24-2013, 05:41 PM Thread Starter
vinnyabs
1983 CJ7
Hey guys. Can someone chime in quickly. My dd and everything brand new suddenly developed a ignition problem. Drive the jeep to destination. Went to leave and nothing happened when I turned the key. Replaced the starter and same. Had battery jumped and it behaved like a bad battery. Slow at first little charge time ad fired up. Drive home shut it off and dead. Battery tested fine. Tried to jump solenoid nothing. Tried to jump wires to positive battery term nothing. Checked fuse box all good. I need to go to work in the morning so I'm dying over ere
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #2 of 31 Old 08-24-2013, 05:45 PM
hp_lovecraft
1981 CJ5
What does the voltage meter show when it was running? maybe the alternator is not charging the battery? You have all the typical symptoms of a failing alternator. Most autoparts stores can test your alternator, and they are pretty cheap to replace since AMC used "off the shelf" items.
A short term solution might be to park on a hill. I had a failing alternator years ago... but push starting a CJ is way harder then a small compact.
hp_lovecraft is offline
post #3 of 31 Old 08-24-2013, 05:50 PM Thread Starter
vinnyabs
1983 CJ7
I don't have a volt meter. I thought alt too but battery tested full strength after the home trip at AZ. When I turn to run position no power at coil. Doesn't make sense that started with a jump and ran if there was ign wiring prob. Plus I haven't changed anything and its been working fine
vinnyabs is offline
post #4 of 31 Old 08-24-2013, 06:04 PM
shadoow
because you were able to jump start it i would suspect the battery, but you said it tested fine. What tests were done??
Also, did you battery and ground connections to be clean and tight? Years ago a friend of mine and I pulled into a gas station and when we went to leave there was no response when the key was turned. Cleaned and reseated the battery cable connections and all was fine.
Is there another battery around you could put in just to see if the problem is still there???
shadoow is offline
post #5 of 31 Old 08-24-2013, 06:05 PM Thread Starter
vinnyabs
1983 CJ7
Battery tested good at AZ. On the machine. CCA an load. Cleaned terminals for giggles anyway last night.
vinnyabs is offline
post #6 of 31 Old 08-24-2013, 06:43 PM Thread Starter
vinnyabs
1983 CJ7
Just tried a new solenoid. Still absolutely nothing. No power to coil. Help!!!!
vinnyabs is offline
post #7 of 31 Old 08-24-2013, 07:01 PM
86cj74.2L
86cj74.2L's Avatar
Wonkie ignition switch.
86cj74.2L is offline
post #8 of 31 Old 08-24-2013, 07:08 PM Thread Starter
vinnyabs
1983 CJ7
Would it have jump started yesterday with a bad ignition switch? With no power to coil in on position, and all connections checked, I guess it's either the switch or the msd right?
vinnyabs is offline
post #9 of 31 Old 08-24-2013, 07:14 PM Thread Starter
vinnyabs
1983 CJ7
I also get light on the circuit tester on the starter pole on the solenoid when the key is turned to start. But still nothing at positive terminal of coil. Is that the msd by elimination? I sure friggin hope not. Plus how would it have driven home if the msd wasn't firing the cylinders? I am completely confused!
vinnyabs is offline
post #10 of 31 Old 08-24-2013, 07:14 PM
Mace350
Clean your negative battery cable where it bolts to the Jeep
Mace350 is offline
post #11 of 31 Old 08-24-2013, 07:17 PM Thread Starter
vinnyabs
1983 CJ7
Please guys. It is a brand new rebuilt engine. It doesn't get any cleaner. And I have said I have good power to everything else just not the coil. I appreciate any an all help but this is a desperate situation and that has been suggested and reported done already.
vinnyabs is offline
post #12 of 31 Old 08-24-2013, 08:36 PM Thread Starter
vinnyabs
1983 CJ7
Any electric gurus? Streak, Hammer?
vinnyabs is offline
post #13 of 31 Old 08-24-2013, 08:59 PM
LumpyGrits
Mount you batteries' main ground to the top mounting bolt of your starter.
You may be loos'n volts via the alt.
Disconnect the alt at night, and see if the battery will hold charge.
Next night with a fully charged battery. Disco the POS(+)battery cable. Does it hold charge?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #14 of 31 Old 08-24-2013, 09:15 PM Thread Starter
vinnyabs
1983 CJ7
Thanks LG. I'll give it a try. So stressed and confused at this point…
vinnyabs is offline
post #15 of 31 Old 08-24-2013, 09:33 PM
86cj74.2L
86cj74.2L's Avatar
Do you have a neutral safety switch on trans or a clutch depressed switch.
If you have no power to the coil in the on position you need to see if power is going to the switch. A test light is easy and cheep.
If you have no power to the switch its time to look at the bulkhead connector. And or the battery's cabling etc.
a crappy ground or grounds will look like all sorts of things its not.
