stupid question? - JeepForum.com
post #1 of 8 Old 10-09-2003, 01:47 PM Thread Starter
NJCJ7
NJCJ7's Avatar
stupid question?
I've been told there are no stupid questions, i hope that applies here.
Anyway, i don't have to get out and lock hubs or anything in my 85 to engage 4wd do I? Just move the shift lever into desired position and go? I am assuming i should be stopped though when i do this? If someone wants to run down the procedure real quick that would be cool...
1985 CJ7 MC2100,TFI, 2.5" BDS suspension, Full Cage, 31" Mud Tires, 1/2" MORE shackles, Aussie Locked AMC 20
NJCJ7 is offline
post #2 of 8 Old 10-09-2003, 02:55 PM
390fastback
390fastback's Avatar
An 85, I beleive you will need to get out and lock the hubs. You could just engage the transfer case, but your wheels would still just be along for the ride. To engage it, lock the hubs (mine stay locked most of the time) and pull the stick back to 4H. You can still be moving, though not really fast, to engage 4 high. I would suggest no more that a few miles an hour (read:no more than 5). I don't know the shift on the fly spec with dana 300's. To hit 4 low though you do need to stop.
390fastback is offline
post #3 of 8 Old 10-09-2003, 04:21 PM
johny1i
johny1i's Avatar
Do you notice a drop in gas mileage with the hubs locked in 2WD? Mine seems more sluggish, but maybe it's just psychological.
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline
post #4 of 8 Old 10-09-2003, 08:36 PM
wm69
Think of it this way, when you engage the lever on your transfer case the front drive shaft spins, so the front axles spin. If you do this without locking the hubs in, the axles aren't "connected" to the wheels; the front axles are spinning, but they aren't driving the wheels. When you lock the hubs in, it connects the wheels to the axles.
If you are driving with the hubs locked in 4wd and the tcase in 2 wd, the front axles are still spinning if the jeep is rolling, cause the axles are "connected" to the wheels. When the wheels spin, it casues the axles to spin, but the front driveshaft is not connected to the engine cause the tcase isn't engaged. Hope I didn't confuse you more.
To simply answer your question, yes you have to lock your hubs AND put the tcase in 4wd to put it in 4wd. Newer jeeps don't requre this cause they have "automatic" hubs. These are nice, but are considered less reliable.
In the late 70's CJ7's I have seen some hubs that automatically lock for light mud, and then you lock them in like regular hubs for heavy mudding/ towing. Seemed weird to me, but they worked good (were on a buddies jeep).
wm69 is offline
post #5 of 8 Old 10-10-2003, 07:01 AM Thread Starter
NJCJ7
NJCJ7's Avatar
Okay, so i have to lock the hubs. Is it okay, as someone said, to drive around with the hubs locked all the time? Also, how do i actually do this? Thanks for all the great info, guys.
NJCJ7 is offline
post #6 of 8 Old 10-10-2003, 07:21 AM
fuzz401
1978 CJ7
some say yes some say no if you read the manual for the jeep it tells you to do it each month to lube the rear up i have locked my hubs in for months at a time and never have had any problems at all with it
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #7 of 8 Old 10-10-2003, 07:43 AM
390fastback
Come winter time, the hubs are locked all the time. Just easier when I get stuck. Done that on every 4wheel drive I've ever had. Noticed a small drop in milage but not really significant.
2000 Cherokee
68 Mustang Fastback (in progress)
71 Mach 1
68 Wildcat (also in progress)
68 International 1200 4x4
78 F150 4x4 400 4spd
post #8 of 8 Old 10-10-2003, 07:53 AM
wm69
Right, it puts a little wear on your drivetrain components (up front), cause your front axles and driveshaft are turning all the time, and it will drag/ lower MPG a little (not even very noticable). I leave mine locked in if the weather is turning snowy/icy, or if I'm going from one muddy spot to another. I don't leave them locked in on the highway (if I'm not definately going into 4wd very soon) cause it's putting unneccesary wear on my front end. May not be a big deal, but here again, it may. Depends on whether you would rather be lazy or rebuild your front end a little sooner.... Not a big deal unless you plan on keeping your vehicle forever (which I do).
wm69 is offline
stupid question of the day... chuckie Jeep CJ Forum 9 02-27-2007 04:48 PM
Stupid Question? Kevmatic Jeep CJ Forum 5 06-28-2006 12:33 PM
stupid 304 question Aaron Day Jeep CJ Forum 1 12-21-2005 05:40 PM
stupid question of the day GKB Jeep CJ Forum 8 12-14-2005 05:43 PM
stupid question lol any help? rukkus0o Jeep CJ Forum 3 07-27-2004 05:31 PM
