Stupid CJ gauges and why I hate them - JeepForum.com
post #1 of 8 Old 01-21-2010, 02:55 PM Thread Starter
IDK
Monday I spent installing the OEM cluster in my Jeep, everything went smoothly and all the gauges worked flawlessly, until I put the amp gauge in, now nothing works at all except the speedo and odometer, wtf went wrong! I don't get it, I had the battery disconnected each time I worked under the dash I don't see how they would have shorted out, this made my whole day, I go and spend 100 dollars on gauges, put em in and they only work for 2 hours, any ideas? I'm going to tackle it again tomorrow, now that my temper tantrum has settled.
JpThang
IDK is offline
post #2 of 8 Old 01-21-2010, 03:15 PM
mtbtweety
mtbtweety's Avatar
1982 CJ8
Did you follow John Strenk's CJ Speedometer Gauge Quick Test guide? The big thing was the ground. If your grounds are crap, you could burn the gauge up quickly. The other links in his signature are like a bible on gauges....
If the grounds are good, double check the connector on the "I" port of the fuel gauge and make sure it's corrosion free. I ended up running a ground from the battery directly to the cluster...
mtbtweety is offline
post #3 of 8 Old 01-21-2010, 03:58 PM
otterred
1976 CJ5
hate to be that guy. But why are you putting an amp gauge in a 1980. are you running a volt gauge too for total electronic monitoring? or did you mean voltmeter and used amp?
otterred is offline
post #4 of 8 Old 01-21-2010, 05:25 PM Thread Starter
IDK
It had a volt gauge in it before, and I put a amp in it instead, it was a gauge I found laying around the shop, it didn't even work either, I think I'm just going to go mechanical if I can't figure it out.
JpThang
IDK is offline
post #5 of 8 Old 01-21-2010, 05:50 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Mechanical volt or amp gauge?
If you wired the amp gauge like the volt gauge then that's your problem.
John Strenk is offline
post #6 of 8 Old 01-21-2010, 09:15 PM
trillobite
John's right.
Voltmeters are wired up to positive and negative (ground), and check the available voltage.
Ammeters measure current flow through the ammeter, and are wired between the positive source, and the items being powered by that source.
Using the voltmeter wires to hook up a ammeter, will short out the battery. You've got a blown fuse, or burnt wire. Unhook the ammeter, replace the fuse, and the other gauges should work again.
Off the subject, though....
What the difference is, between a mechanical voltmeter, and a electrical voltmeter. Both are electrical devices, aren't they? Is it the difference between measuring the voltage across a resistor with a analog gauge, as opposed to measuring the voltage with a transistorized circuit, which feeds a voltage gauge?
trillobite is offline
post #7 of 8 Old 01-22-2010, 10:00 AM
Pathkiller
1974 CJ5
There's a huge flaming reason why Jeep stopped installing ammeter's and switched to volt meters. Fire. The ammeter runs the full battery amperage through the gauge. If the gauge fails (which they are prone to do) you will end up with a smoking hot flaming mess. Many Jeeps have gone on to Jeep heaven because of this. DO NOT install an ammeter unless you know what you are doing. The volt meter is way less dangerous and can be powered by a fused source, which is 100 times safer.
Pathkiller is offline
post #8 of 8 Old 01-22-2010, 10:24 AM
dwloop
1976 CJ5
Well, the other reason is that an ammeter really does not portray the health of the system, it could be charging like hell and the ammeter is pegged and still be dropping voltage…
Dave
dwloop is offline
Mechanical gauges DEFINETELY better than the stock electical gauges jeepguy85 Jeep CJ Forum 33 01-14-2010 08:20 PM
I hate to ask, but....... 4XGore Jeep CJ Forum 18 05-04-2007 06:31 PM
My neighbors must hate me!! BESRK Jeep CJ Forum 2 08-07-2004 08:27 PM
stupid fuel & temp gauges 84cj-7 Jeep CJ Forum 3 04-28-2004 10:51 PM
bangin' a stupid dent out of my stupid hood! c-dogg Jeep CJ Forum 7 04-12-2004 06:00 PM
