Stuck bolt removal - JeepForum.com
post #1 of 5 Old 05-18-2003, 10:01 AM Thread Starter
BIGJMCCONNELL
1977 CJ7
Stuck bolt removal
Hello All:
I think I pretty much know what everyone is going to say about this but I thought I would post and see.
So I have a fiberglas windshield frame and I was trying to get the hardware off to replace it and paint. Simple task ...not.....I am having a huge amount of trouble with the bolts. The first problem is that they are flat headed sloted bolts which are worse than torx for getting a good hold on. I broke one off and then drilled out the bolt and tried to get it out with an easyout but the nut spun inside the fiberglas. So now I am screwed and I don't know how I am going to fix that. I guess some bondo but I don't know if that will hold???? And i still need to work on the others. Maybe today is a new day and they will coperate
1977 CJ-7 with Ford 302 engine
2.5 inch springs Matkins Frame with 1.5 inch body lift and all Fiberglass body D30/M20 w/3.54 gears, Moser 1-piece and Rear Aussie Locker, Jeep T-18w/Dana 20 and 35" tires Dual Flowmaster Exhaust, 6 point roll cage, OBA and a bunch of other stuff.
BIGJMCCONNELL is offline
post #2 of 5 Old 05-18-2003, 08:26 PM
fuzz401
1978 CJ7
depends on the hole size you could try a nutsert they work good and a little neverseizh on the bolts
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 5 Old 05-18-2003, 09:43 PM Thread Starter
BIGJMCCONNELL
1977 CJ7
what exactly is a nutsert? Yeah neversiez is key I use it all the time ....I just wish the guy before me had used it. That would have kept me out of this problem.
--john
post #4 of 5 Old 05-18-2003, 10:15 PM
fuzz401
1978 CJ7
http://www.broncofix.com/Tech/nut/nut.htm
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #5 of 5 Old 05-19-2003, 08:52 AM Thread Starter
BIGJMCCONNELL
1977 CJ7
thanks fuzz
That may be just what I was looking for.
--John
broken bolt removal BlueFalcon Jeep CJ Forum 5 09-29-2009 08:34 AM
Body Lift Bolt Removal CJhollic Jeep CJ Forum 0 04-04-2009 10:19 AM
Amc20 cover bolt removal beastofacj Jeep CJ Forum 9 09-03-2006 01:15 PM
stuck leaf spring bolt mickeymountain Jeep CJ Forum 6 11-20-2004 10:00 PM
1976 CJ5 Body Mount bolt removal certifiablejeep Jeep CJ Forum 6 09-08-2002 08:24 AM
