Stuck in 4WD - JeepForum.com
post #1 of 10 Old 02-06-2002, 11:21 PM Thread Starter
CJ7Eric
Post Stuck in 4WD
Anyone hear of their stick to change into 4WD getting stuck? For some reason the other day I put it in 4WD locked the hubs and today I can't get it out. I have tried psushing real hard and visibly I see no problem below. Any ideas?
CJ7Eric is offline
post #2 of 10 Old 02-06-2002, 11:22 PM Thread Starter
CJ7Eric
Post
BTW: I have an 83 CJ7.
CJ7Eric is offline
post #3 of 10 Old 02-06-2002, 11:28 PM
Jeep CJ5
Post
You need to try and release the tension on the transfer case. I usually used reverse on a loose road surface. I had a finicky 85 CJ7 that took a wee bit of finesse to get out of 4wd.
Do not use brute strength.
Anyone more tech savvy have any more insight?
1974 CJ5 Renegade...restored...100% perfect
too nice to be true!!!
Jeep CJ5 is offline
post #4 of 10 Old 02-07-2002, 12:32 AM
jeepster18_88
Post
First, I would unlock the hubs if they aren't already. This might take off some tension. If that doesn't work and the reverse thing doesn't work, lift the entire jeep off the ground. Put in on jackstands, crank it up and then try to put back in 2wd. If all this fails, lower the jeep, hold the transfer shifter with a slight pressure, put it in 1st gear or reverse and slowly let out the clutch while pulling on the shifter. Try this and it may slip out. Hope it helps. Let me know of your success.
Josh
jeepster18_88 is offline
post #5 of 10 Old 02-07-2002, 08:53 AM
T Hoff
1975 CJ5
Post
I usuallt stop on some soft beach sand so gears can float around a bit to pop it out.
Mine is a manual trani, sometimes you can let the clutch out so you roll forward then press the clutch down and pull the lever back. The idea is the same, take tension off the drivetrain so the meshed gears can release.
'75 CJ5 ---Chevy HP 350 motor-- All Fiberglas---one piece tilt forward nose
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
T Hoff is offline
post #6 of 10 Old 02-09-2002, 12:13 PM
Viper Red CJ
Post
The same thing happened to me.
I have a DANA 300 Transfer case, and I was stuck in 4wd. I popped it in reverse, but couldn't move it very far, and it didn't help. What solved my problem was using the engine as a brake (decelleration) to put reverse torque on the transfer case, and it shifted back into 2wd without a problem.
Viper Red CJ is offline
post #7 of 10 Old 02-10-2002, 07:07 PM
MR.CJ-7
Post
All are good tips. I have used them all from time to time. Seems the D300 binds up some times. The deceleration trick seems to work best for me.
Former CJ'er
MR.CJ-7 is offline
post #8 of 10 Old 02-11-2002, 09:29 AM Thread Starter
CJ7Eric
Post
HI all. I tried all of these tricks and the one that worked was the deceleration trick. It took some time before it actually worked but I got it out of 4WD. Its kind of a weird little thing. Thank you all for your help.
CJ7Eric is offline
post #9 of 10 Old 02-11-2002, 09:34 AM
Guy Hollister
Cool
I have this problem all the time and also not much easier getting it into 4WD either .... is this the famed tranny windup ? and requires reversing for some 200 yards to rid it ? Or am i on the wrong track here ?
I am sick of sitting there for 5 mins while traffic builds up !
g
1984 RHD CJ7
1979 LHD CJ5
Guy Hollister is offline
post #10 of 10 Old 02-17-2002, 11:56 PM
Cophgnsnuf
Post
I have had this problem several times with my 82.. I find that putting it is 1st gear and slowly letting out on the clutch at the sametime as trying to put it back in 2 wheel works best for me..
82 CJ7 36" superswampers. SOA ,2 1/2 inch lift springs and a whole lot of dreams. My baby.
Cophgnsnuf is offline
stuck in 4 low hercj5 Jeep CJ Forum 11 05-15-2008 12:49 PM
Help- Key Stuck jrick Jeep CJ Forum 2 01-18-2008 06:16 PM
stuck in 4hi c-dogg Jeep CJ Forum 4 01-22-2004 11:53 AM
I am stuck!!! kev1 Jeep CJ Forum 3 07-22-2003 08:24 AM
stuck brown blob Jeep CJ Forum 7 02-19-2003 03:45 PM
