stubborn pedal - JeepForum.com
post #1 of 4 Old 02-22-2002, 03:02 AM Thread Starter
MB83CJ7
Post stubborn pedal
I own an 83 cj and while its running the accelerator is very hard to press at a point past that its fine, or while the engine isn't running? any suggestions?
MB83CJ7 is offline
post #2 of 4 Old 02-22-2002, 07:17 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
I think you need to check the entire length of the throttle cable for kinks or binding spots. Especially check where it goes through the firewall. If you have kink, replace it - better safe than sorry. If it seems OK, use some white lithium grease to lube all of the spots you can. Also hit the pedal pivit points, basically any part that has to move when you use the go-juice.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 4 Old 02-22-2002, 08:06 AM
coopcj7
Talking
I am goignto have to agree with CJeep you need to check the whole cable. Like he said better safe than sorry especially if the throttle decides to stick open and races you down the highway when you are trying to stop. Use the grease in the easy reach palaces but if you want to lube the inside as well spray some WD 40 on it and put a couple drops of oil and let it works its way through
Brian Cooper
1977 CJ7
Glass body
304 bored over .030
Chevy 350 coming soon (i hope)
2in lift
31" Cooper HT's
custom 2 wheel drive (temporary)
coopcj7 is offline
post #4 of 4 Old 02-22-2002, 07:16 PM Thread Starter
MB83CJ7
Post
for some reason when the engine is running the throttle linkage at the carb gets very tight, but if I could change the angle of the linkage I think I can remedy this problem. Or if I could keep the linkage from tightening up.thank you for your input.
MB83CJ7 is offline
Stubborn valve cover on 258 kpauley Jeep CJ Forum 25 08-27-2009 11:59 AM
Removing a stubborn stud - Solution! attworth Jeep CJ Forum 13 08-09-2009 05:11 PM
Stubborn, rusty, broken off #%$#@! bolts skidplate77 Jeep CJ Forum 13 07-16-2008 03:53 PM
Gosh darn stubborn bolts! gmshades Jeep CJ Forum 9 06-19-2007 09:36 AM
stubborn start-up skyjeep Jeep CJ Forum 2 03-07-2003 10:32 PM
