Strengthening Stock Tie Rod - JeepForum.com
post #1 of 11 Old 06-04-2013, 06:24 PM Thread Starter
elks96
So I bent my tie rod all up this last trip in Moab. I have a second factory tie rod sitting in my parts pile. I am saving up for a heavy duty one with a tie rod flip, but that is 2-3 months out.
Can I make my factory one stronger? Sleve it with another piece of stock? If so what size tube?
1985 CJ 7 258 bored/Cammed, MotorCraft Carb, Mallory Ignition, NP435/Dana 300, 4.5 RE Ex, 1.25 JKS Body Lift, Detriot AMC 20 Rear(detroit locker and Warn Hub Conversion), Herculined Tub, Chevy Heater Blower, 34" Swampers, Custom Rear Bumper, more to come....
1972 K5 8" lift, 36" swampers, lockers, custom paint.
elks96 is offline
post #2 of 11 Old 06-04-2013, 07:01 PM
TKFireman
1980 CJ7
When I bent mine, I straightened it then sleeved it with black iron pipe from the hardware store, forget what size but it fit perfect. I drilled holes down the pipe and plug welded it. It has to end a little short to leave room for the clamps that tighten up on the TRE. I'm sure you could find a stronger pipe to use like DOM, but at that point you might as well just make your own heavy duty one. The black iron pipe was cheap, easy to get, and made it stronger than stock.
"If your gonna be dumb, you gotta be tough"
Build Thread
TKFireman is offline
post #3 of 11 Old 06-04-2013, 09:49 PM
lucdog
1980 CJ5
I did the same only used tube, not DOM, just regular 1/8" wall stuff . I cut slots with a 1/4" grinder and plug welded it that way. I also welded it at both ends
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #4 of 11 Old 06-04-2013, 11:01 PM
82JeepCJ7
1982 CJ7
I just did mine with the black iron pipe not long ago.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #5 of 11 Old 06-04-2013, 11:57 PM
titomars
1981 CJ7
In the old days doing fleet work back when most P/U's and bigger trucks were beam axles. We used to stitch weld a piece of angle iron across the tube. It did two things, salvaged a bent tie rod back into service and strengthen it at the same time. a piece of pipe/tubing works better for strengthening but you will play hell straightening a rod out and get it down a piece of pipe.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #6 of 11 Old 06-05-2013, 12:06 AM
VooDoo2
1978 CJ7
Not sure about the USA but down here any welding on the steering arms is illegal and the car would be defected if you did as discribed. Is the US similar (officially)? I know what can be done and works but interested to hear if there is a legal issue over there with doing this.
VooDoo2 is offline
post #7 of 11 Old 06-05-2013, 12:12 AM
titomars
1981 CJ7
It is illegal to do that on commercial trucks now a days. Probably is here in the states that have annual safety inspections for private vehicles too. I was talking 30 years ago.
titomars is offline
post #8 of 11 Old 06-05-2013, 09:47 AM
82JeepCJ7
1982 CJ7
We don't have inspections or emissions testing here. Plus, unless it fails and causes an accident, law enforcement is not going to know the difference. I'd never weld on a Pittman arm, as they are cast. Just the tie rod and drag link.
post #9 of 11 Old 06-05-2013, 10:36 AM
Renegade82
1982 CJ7
That's what I was going to suggest, since it's only for 2-3 months. But I doubt it would pass inspection if that falls in the same time frame.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline
post #10 of 11 Old 06-05-2013, 11:11 AM
82JeepCJ7
1982 CJ7
You can straiten the stock tie rod pretty easy. Its not that thick. I did it with my bench vise. Clamped it in the vise right before the bend, then bent it strait by hand. Rolled it on the floor to make sure it was strait. Any adjustments, in the vice it went. It's not rocket science.
post #11 of 11 Old 06-05-2013, 11:25 AM
titomars
1981 CJ7
I would guess it depends on the OP's state and if they even do inspections.
California and Nevada don't inspect other than smog
titomars is offline
