Strange wiring problem, I need help guys!! - JeepForum.com
post #1 of 10 Old 09-10-2011, 11:31 PM Thread Starter
nanks79cj5
1979 CJ5
ALright, so when I bought my 79 cj5 the only problem with it other than bearing and axles and rust was that there was a short in the turn signals so they had been unplugged. The PO thought that the short laid within the switch so that gave me a starting point, I bought a new(ish) turn signal switch and replaced the old one, when I plugged it in and tried the signals only the right front worked! Before I went to town to pick up new bulbs for the three that did not work I turned my head lights on and noticed that my left (drivers ) side parking lamp no longer worked, so i went and got new bulbs and still nothing in the right parking lamp, I replaced the socket, and I am still not getting any juice to the right front parking lamp, where as I was before I installed the new turn signal switch!!! So now I have no idea what could have happend or where to start, any advice? thanks: Nank
Edit: Sorry guys I meant the left front parking lamp not the right
nanks79cj5 is offline
post #2 of 10 Old 09-10-2011, 11:48 PM
hybridmoments
1978 CJ5
Check the ground on the actual light.
hybridmoments is offline
post #3 of 10 Old 09-11-2011, 03:51 PM Thread Starter
nanks79cj5
1979 CJ5
I have checked the ground on the both the parking lamp and the headlight they seem fine????
thanks
post #4 of 10 Old 09-11-2011, 06:55 PM
hybridmoments
1978 CJ5
thanks
You have a voltmeter? You should invest in one and see where the disconnect is. If you are getting voltage to the light then just try swaping a bulb from the other parking light and see if it lights up.
There's a good chance the grounds are bad though FYI> Also check the connections on the back of the gauge cluster.
post #5 of 10 Old 09-11-2011, 07:03 PM
Cjcpdo
Sounds like a mouse chewed your wires up. If all the grounds are good I would start tracing wires.
Cjcpdo is offline
post #6 of 10 Old 09-11-2011, 08:40 PM
BagusJeep
1981 CJ7
You can get bad grounds, worn out light fittings, chewed cables, fried relays etc. As you have now discovered just swapping parts does not necessarily fix an electrical issue. However do not be docuraged, those parts would have broken at some time anyway.
The only way to get it to work is to be methodical and find where you have voltage and where you have continuity.
I would start at the light fittings and look for voltage. Then go back to the relays then the switch and also test the cables in between for continuity once you have stablished how far back in the circuit you have voltage .
You will need a test light and a wiring diagram and be VERY methodical. A meter is useful but with a $5 test light and a longish lead you can get these circuits tested.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #7 of 10 Old 09-11-2011, 10:59 PM Thread Starter
nanks79cj5
1979 CJ5
alright thanks guys, i will trace wires tomorrow evening, and would the wiring diagram in the chiltons guide be sufficient or should i google one?
post #8 of 10 Old 09-11-2011, 11:25 PM
Cjcpdo
Never looked at chiltons, if it tells you wire color it should help plenty.
Cjcpdo is offline
post #9 of 10 Old 09-12-2011, 12:25 AM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Sorry to highjack!
Bagus, so you're saying you can test voltage and continuity with just the screwdriver type test light ?
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #10 of 10 Old 09-12-2011, 04:45 AM
skizriz
1978 CJ7
Try this one. When I rewired I found it to be a life saver compared to Chiltons.
http://www.offroaders.com/tech/image...agram-1978.pdf
For the actual 1979 diagram, just change the year in the link.
skizriz is online now
cj5 , headlights , parking , wiring for lights
Strange problem !! Elkaholic Jeep CJ Forum 19 05-11-2011 08:37 PM
One for you wiring guys Truck633 Jeep CJ Forum 22 03-27-2011 10:13 PM
Strange Electrical Problem White92 Jeep CJ Forum 6 10-01-2008 04:18 PM
Sorry Guys, HEI wiring question Shameless Elmer Jeep CJ Forum 15 07-24-2007 12:15 AM
Strange problem - please help Joey_B Jeep CJ Forum 25 11-27-2006 04:50 AM
