Strange (well, for me!) sounds from the drivetrain - JeepForum.com
post #1 of 6 Old 10-05-2013, 11:18 AM Thread Starter
XLarge
for a couple of days i hear strange sounds from somewhere under my car.
it is loudest in 5th gear (258 cui, T5) and occurs if i roll and then touch the gas slightly and if i drive slow and release the gas quickly. It might also occur while going faster but i think the engine is too loud to hear it through.
it sound like a metallic "klack" somewhere in the middle of the car(?).
where should i begin the search?
maybe the u-joints of the drive-shaft? could they be worn out and rock under load changes?
i hope i chose the right terms (with the help of leo.org).
gtx from germany
Micha
XLarge is offline
post #2 of 6 Old 10-08-2013, 08:51 AM Thread Starter
XLarge
is this too easy!? i just tuned my weber right but with the heavy metal parts (drivetrain) i'm not yet familiar.
maybe i keep it like this and wait until it gets worse.
gtx
XLarge is offline
post #3 of 6 Old 10-08-2013, 09:06 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Hi gtx,
Strange noises or vibrations in the driveline, under load only, are usually caused by bad u-joints.
Matt
Matt1981CJ7 is offline
post #4 of 6 Old 10-08-2013, 05:44 PM
LumpyGrits
X2 on what Matt sez, and broken eng/tranny mounts will do it too.
When was the last time you lubed your U-joints and the DS slip spline?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #5 of 6 Old 10-09-2013, 12:25 AM Thread Starter
XLarge
lubed regularly. I'll check that this weekend. thanks for your replies.
XLarge is offline
post #6 of 6 Old 10-09-2013, 08:34 AM
LumpyGrits
Don't drive it till you locate/fix this issue.
LG
