strange starting issue at the key switch - JeepForum.com
post #1 of 5 Old 01-08-2010, 01:42 PM Thread Starter
joes1982CJ
the 84 scramber w/258 i have been working on has been having some starting issues and im hoping you all can help.
basically what happens is this,,, i turn the key to the start possition and it cranks and doesnt fire and when i give up and release the key from the start possion is fire and runs perfectly. this happens weather i crank it for 2 seconds or 10 seconds, wont fire until i start the release the key front start.
strange thing is this, it only does this when its warmed up, if its a cold start it works just as it should ( it will fire when im holding the key in the start possition ) ..
there is another twist here,,,
if i start this thing up after its been sitting over night or something it will idle fine on the driveway then suddenly just die. so once this happens i go to start it and thats when the key switch issues comes about. i recently swaped the stock cab out to the howell efi set up and it still does this.
could it be thats the ignition switch is bad? does any of this add up to something anyone can think of? im thinking of installing a new ingnition switch thing,,, i have read that its on the bottom of the column or something. does anyone know a good place to buy one?
thanks in advance
joes1982CJ is offline
post #2 of 5 Old 01-08-2010, 02:19 PM
John Strenk
John Strenk's Avatar
1976 CJ5
At first I'm thinking starter solenoid myself. The starter solenoid should supply power to the ignition coil when cranking. THis is done to add full power to the coil by by-passing the resistor to the coil. There may be parts of the solenoid it's not making contact. If the post on the ends of the solenoid get twisted when tightening the wires then one side of the solenoid could be sticking up not allowing the contact ring to seat all the way. It could also get stuck on the way down to make contact. However it will not cause a problem with the jeep just dieing at idle.
However an ignition switch could also cause a problem with it just dieing or starting. The ICM will only get power through a resistance wire fed from the starter solenoid and that may not be enough to fire the spark. When the key is released it makes a better contact with the terminals that finally supply power to the ignition system. Any thing else not working properly when the jeep dies?
So the ignition switch could cause both problems so I might suggest testing or replacing that right first.
Just about any auto parts store wll have one. They are different between tilt and non-tilt steering columns.
Two screws hold them on and a rod connects it to the key cylinder. Pretty easy to replace and adjust .
John Strenk is offline
post #3 of 5 Old 01-08-2010, 02:29 PM Thread Starter
joes1982CJ
solenoid definatley makes sense. everything else "seems" to be working ok when the jeep dies,, not really sure what you mean? all the guages still seem to read correctly and the lights etc, once it dies, nothing out of the norm. i cant see anything else electrical that is acting up.
thanks for the response
post #4 of 5 Old 01-08-2010, 02:52 PM
John Strenk
1976 CJ5
I'll have to check but some circuits run off a different section of the Ignition switch so if one section fails then the rest could still be working.
post #5 of 5 Old 01-08-2010, 03:23 PM Thread Starter
joes1982CJ
sounds good, if you happen to check let me know
Strange electrical issue? HHICJ7 Jeep CJ Forum 6 11-04-2009 12:29 PM
Re-starting AMC 360 issue StewartCJ7 Jeep CJ Forum 3 09-24-2009 10:45 AM
starting issue htmahley Jeep CJ Forum 7 06-03-2009 04:22 PM
Starting Issue jmdkb12 Jeep CJ Forum 4 03-16-2009 04:05 PM
starting issue, 304 BlueFalcon Jeep CJ Forum 24 01-10-2007 07:22 AM
