Strange question about idle problem - Page 7 - JeepForum.com
post #91 of 116 Old 06-22-2013, 08:38 PM Thread Starter
ryancrotty
When it's idling I don't see any fuel, so no dripping fuel. When it dies what is the best way to check for spark?
ryancrotty is offline
post #92 of 116 Old 06-22-2013, 10:58 PM
86cj74.2L
86cj74.2L's Avatar
Pull a spark plug wire, jam a screwdriver in the end and hold it 1/4 inch away from metal while someone tries to start it. If no spark I'd concider replacing the coil. Grammys I thought had two wires on the plus terminal. But if you read 4 or so volts from the plus terminal to ground while the engine is running the coil is not overheating from getting full voltage.
If you have spark depress the gas pedal a few times and see if fuel squirts out the accelerator pump nozzles. Each squire should be a long strong squirt. Do a few.
If nothing comes out or its weak in the beginning then goes to nothing I'd look at the fuel filter, fuel pump, vacuum building up in the gas tank, or vapor lock. I hope your using the factory (1 inlet and 2 outlet) fuel filter.
86cj74.2L is offline
post #93 of 116 Old 06-23-2013, 10:08 AM
LumpyGrits
NO-NO screwdriver etc!..............................
That will do harm to the 'puter. There was, at one time an AMC notice about do'n just this.
Use an inductive timing light to check for spark.
The coil should be a little hotter to the touch, than you can hold is all.
LG
LumpyGrits is offline
post #94 of 116 Old 06-23-2013, 10:11 AM Thread Starter
ryancrotty
My fuel filter doesn't have the double on one end it is just the single. If I switch it where would I hook u the second one on top since I dont have a factory air cleaner. Could this cause it to shut off when hot and need to sit. Would this have any effect on the coil getting hot? Is that even a problem? Should it get hot? Every one I had in there is getting hot, the coil in there now has only been ran 20 min.
post #95 of 116 Old 06-23-2013, 10:27 AM Thread Starter
ryancrotty
Ok so it being hot is normal, it most likely is getting spark everything now is new that would have to do with spark.
post #96 of 116 Old 06-23-2013, 10:33 AM
LumpyGrits
Have you replaced the cap/rotor and s'plug wires?
If so-Hope your cap has brass contacts and NOT alum.
Old plug wires will 'ground-fire' and that will cause a coil to over heat.
LG
post #97 of 116 Old 06-23-2013, 11:17 AM
INowUnderstand
Since you don't have a return fuel line on fuel filter have you investigated the vapor lock situation mentioned earlier.
INowUnderstand is offline
post #98 of 116 Old 06-23-2013, 12:01 PM Thread Starter
ryancrotty
I have done cap rotor and wires as well and it does have brass. How would I found out if it is vapor lock?
post #99 of 116 Old 06-23-2013, 12:41 PM
86cj74.2L
86cj74.2L's Avatar
By following my procedure while watching the accelerator pump squirt.
LG what in the world are you talking about? Unless your really stupid will you blow up anything computer related. And that involves removing the coil wire from the coil and turning over the engine and having a spark jump out of the coil center and zap the green wire on the coil.
post #100 of 116 Old 06-23-2013, 02:00 PM
86cj74.2L
86cj74.2L's Avatar
You really should have that three port fuel filter. There should be a smaller line around the motor mount that's the return line back to the tank. If there is no cap on it I'd go to the other end and blow air through it.
post #101 of 116 Old 06-23-2013, 02:52 PM Thread Starter
ryancrotty
Ok I'll take a look when I get home tonight. Thanks for all the help you guys have been great. Hopefully I'm heading in the right direction
post #102 of 116 Old 06-23-2013, 07:17 PM Thread Starter
ryancrotty
Ok so i got home and found a fuel line that ran all the way back to the tank with nothing attached to it. It was also prob only like 7 inches or so from the fuel filter. It looks like the PO just put the wrong filter on it and just left the line unhooked and unplugged. Hopefully this will fix the problem. Ill keep you updated.
[IMG][/IMG]
post #103 of 116 Old 06-23-2013, 09:46 PM
INowUnderstand
That looks like the return line. Just replaced my filter. You just need to get a hose to connect the line to thr filter and make sure that return line is at 12 oclock on top position.
post #104 of 116 Old 06-24-2013, 10:06 AM
LumpyGrits
There was a TSB sent to NOT do this with the direct fire to block as it could damage a sensor/'puter/etc . THAT'S WHAT I'M TALK'N ABOUT!
I'm also talking about intermittent ground arcing("leaking")from old spark plug wire due to high resistance from the old wires. this will cause a coil to over heat as you are 'shorting' the coil.
BTW, best to do the 'test' with an old spark plug touching the block and not a screwdriver jammed into the plug wire.
LG
post #105 of 116 Old 06-24-2013, 10:07 AM
LumpyGrits
You better clean the dirt from that line before it's all flushed into the tank.
LG
