Strange question about idle problem - Page 6 - JeepForum.com
post #76 of 116 Old 06-20-2013, 07:23 PM
LumpyGrits
REALLY hope you didn't buy more China made CRAP to save a dollar!
LG
LumpyGrits is offline
post #77 of 116 Old 06-20-2013, 07:52 PM
86cj74.2L
86cj74.2L's Avatar
Originally Posted by ryancrotty
Ok so I'm picking up a new ICM and coil on the way home, Also I checked the voltage on the coil with the engine and it was about 4 volts.
That my friend is why I pulled the MSD6A off my Daytona and installed it on the jeep. Haven't touched it since.
86cj74.2L is offline
post #78 of 116 Old 06-20-2013, 08:14 PM Thread Starter
ryancrotty
so i ended up talking to NAPA and ordered the parts from them. i asked the guy if they were made in america he said yes. Is there any brand or part numbers i need to make sure i get the right ones, or just made in america, and none of this Chinese crap.
ryancrotty is offline
post #79 of 116 Old 06-20-2013, 08:20 PM
LumpyGrits
NAPA 'Gold line" is what you want............
As per PN's not a clue. Trust the NAPA guy, they are the BEST.
BTW, BEFORE you do the install------Disconnect the POS(+)on the battery!!!!
LG
post #80 of 116 Old 06-20-2013, 09:28 PM Thread Starter
ryancrotty
Sounds good. Is this going to keep it from shutting off, and fix it. i dont want to be just throwing money at parts. Are there any other things i should be checking? Like relays or sensors that could be causing this?
post #81 of 116 Old 06-20-2013, 10:40 PM
86cj74.2L
86cj74.2L's Avatar
You still need to take care of the dripping Venturi
post #82 of 116 Old 06-20-2013, 11:07 PM
86cj74.2L
86cj74.2L's Avatar
Soo while your waiting for your parts pull that cluster and clean it.
post #83 of 116 Old 06-22-2013, 08:45 AM Thread Starter
ryancrotty
Ok cluster is clean and I'm hoping to get the parts put on later this afternoon. I really hope we will be good to go.
post #84 of 116 Old 06-22-2013, 02:48 PM
86cj74.2L
86cj74.2L's Avatar
Hopefully the passages from the fuel bowl to the cluster are not full of dirt also.
You ran a stiff wire through the brass tubes and shot carb cleaner through it?
Was there a little ball inside the cluster? Their should have been.
post #85 of 116 Old 06-22-2013, 03:24 PM
LumpyGrits
A copy of the OEM, FSM-MR-252 would walk you through the carb tear down.
http://www.civilianjeep.info/84-86FSM/CJ-FSM-84to86.pdf
LG
post #86 of 116 Old 06-22-2013, 03:26 PM Thread Starter
ryancrotty
I ran wire up into the tubes and blew carb cleaner in them. Should I be able to run the wire and make it all the way through? I did not see a little ball in the cluster. Where would it be?
post #87 of 116 Old 06-22-2013, 03:30 PM
LumpyGrits
Unless the wire is .003" dia or smaller it will not pass through.
If you would download the FSM that I just posted for you. You would ans your own question and learn much about your Jeep.
That FSM is a 'Bible'........
LG
post #88 of 116 Old 06-22-2013, 04:52 PM
86cj74.2L
86cj74.2L's Avatar
There should be a small ball in the hollow part between the halves of the cluster. I feel it should be there. Some here think it may not matter.
post #89 of 116 Old 06-22-2013, 08:53 PM Thread Starter
ryancrotty
Ok put new ICM and new coil in and cleaned the cluster more. It fired up ran great for a while let it run for about 10 min took it for a few spins around the neighborhood then about 15 20 min in it died again when I came to a stop. The engine is running better and idling better than ever before after everything I've done. I have to let it sit for a few min before it starts up again. The new coil is also getting kinda hot as well. Am I back to a bad float or float adjustment? New ideas?
post #90 of 116 Old 06-22-2013, 08:55 PM
86cj74.2L
86cj74.2L's Avatar
Is it still dripping out the Venturi cluster?
When it stalls and won't restart try checking for spark. If you have it its fuel or carb related. If not..........
