*Strange Dana Spindle Nuts* - JeepForum.com
post #1 of 5 Old 11-22-2002, 09:32 PM Thread Starter
only in a jeep cj
On a few Dana 44's that I have worked on, Scout II's mainly) I have noticed a different spindle nut set up. Instead of the usual nut, bent lock washer, nut, washer, bearing.... set up it consist of a round nut with 3 set screws that lock into a index ring (round washer with many holes that match the outer set screws) and then the second nut and so on... Does anyone know what I am talking about and where can I get these????? They fit both Dana 30 and 44 spindles. All of the parts places think that I am nuts>
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #2 of 5 Old 11-22-2002, 11:53 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Yea, Ive seen a couple of these. I assume that there is a problem with yours and you are trying to replace it. If I remember right, you should be able to replace them with the GM/Ford set up consisting of a pinned inner nut, indexing lock washer, and outer lock nut. If you change over, be sure that the outer nut tightens past the outer edge of the spindle, as some spindles are slightly shorter than others. If this is the case with yours, use a bearing nut from a CJ to lock the assembly,as this nut is thinner than the upgrade.
jeepdaddy2000 is offline
post #3 of 5 Old 11-23-2002, 01:12 AM
CSP
That's your typical Dana 44 setup. There's really nothing strange about them. Typical of the Dana 60 also. The Dana 30 is the only one that uses the bent washer POS. FYI there is also a single nut that Ford used in their 44's that requires not locknut or indexing washer. You simply tighen it until it ratchets and you're done. You can find it on www.jeepwire.com in the Jeep tech section. Works on Dana 30's also.
CSP is offline
post #4 of 5 Old 11-23-2002, 01:32 AM
jeepdaddy2000
1971 CJ5
Originally posted by CSP
Ummm, that's your typical Dana 44 setup. Typical of the Dana 60 also. The Dana 30 is the only one that uses the bent washer POS. FYI there is also a single nut that Ford used in their 44's that requires not locknut or indexing washer. You simply tighen it until it ratchets and you're done. You can find it on www.jeepwire.com in the Jeep tech section. Works on Dana 30's also.
One thing to remember about the one piece ratcheting spindle nuts is that you MUST have a spindle nut wrench to loosen them, since the fingers depress the inner locking mechinism. No screwdrivers and hammers here. They are, however, much simpler to use.
post #5 of 5 Old 11-23-2002, 10:33 AM Thread Starter
only in a jeep cj
Thanks, didn't know that they were that common......I've seen both the bent washer AND the set screw kind in the 44's and only the bent washers in the 30's. (as you said) Mine are fine, I just like the set screw style better then the bent washer and want to upgrade them in my Dana 30....I did see the ratcheting Ford kind and the Ford kind with the small pin that is punched in to the small aligning hole.....I'm looking at cost and I already have the tools for the others. Anyone know where to purchase the set screw kind new? If not, I'll try the junk yard.
Ed
1975 CJ-6 1983 CJ-8
Torque spec for spindle nuts OldSailor Jeep CJ Forum 11 05-28-2015 12:08 PM
Spindle Nuts... Eagle2 Jeep CJ Forum 3 03-31-2009 12:27 AM
Dana 30 spindle nut size? FRITCHERC Jeep CJ Forum 6 08-30-2008 12:06 PM
dana 30 spindle brandxj Jeep CJ Forum 1 04-01-2005 11:58 AM
Dana 30 spindle nut size SQF1 Jeep CJ Forum 3 01-08-2005 06:47 PM
