strange brake light switch - JeepForum.com
post #1 of 5 Old 09-18-2011, 06:57 AM Thread Starter
rbush
I am working on the brake lights on my 1976 cj5. The brake light switch does not look like anything I have seen listed for any of the cj's. It is at the pedal (not a pressure switch). It is actually mounted to the column with a spring actuator that is on the pedal. The switch itself is a small microswitch. When the pedal is at rest, the spring should (it does not but it should) make contact with the switch. It actually looks like there used to be another piece on the end of the spring that actually came in contact with the switch. I know, vague description. I will try to get some pictures later today. I just thought somebody might recognize this setup from my bad description. I would like to replace it, but don't even know what to ask for
rbush is offline
post #2 of 5 Old 09-18-2011, 01:07 PM
jumbojeepman
1976 CJ7
It should be a black cylinder just above the steering column with a red or white plunger. The connection end points towards the steering wheel. It's a fairly standard part (either GM or Ford, can't remember which.) When the pedal is not pressed, the plunger is closed, interrupting power to the brake lights, and when you press the pedal the plunger expands and the brake lights come on.
jumbojeepman is offline
post #3 of 5 Old 09-18-2011, 04:33 PM Thread Starter
rbush
This is what it looks like
Well That is what I thought I would see, Not sure how to post a picture, but here is a link to some pictures I shot earlier today and posted to shutterfly
http://ralphsjeep.shutterfly.com/pictures?role=-1#n_5
There should be three pictures of the switch there.
rbush is offline
post #4 of 5 Old 09-18-2011, 06:47 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Any way to see the pictures without joining shutterfly?
John Strenk is offline
post #5 of 5 Old 09-18-2011, 08:07 PM Thread Starter
rbush
Well, I seem to be having posting pictures. I hope that they appear this time.
rbush is offline
'72 CJ5 brake light switch shank38242 Jeep CJ Forum 2 04-29-2009 06:14 PM
where is the brake light switch bobby0872r Jeep CJ Forum 5 03-10-2009 11:04 PM
Brake light switch/turn signal switch ivaskaj Jeep CJ Forum 19 07-31-2008 06:15 AM
brake light switch 82cjman Jeep CJ Forum 3 12-05-2007 11:10 AM
brake light switch jgoshow Jeep CJ Forum 5 07-23-2007 04:45 PM
