Quantcast Stock Steering Shaft - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Stock Steering Shaft
Old 01-04-2007, 01:45 PM   #1
1979CJ7
1979 CJ7
I am converting my tired gearbox to a better one and when I went to put the steering shaft back into place it was about 3 inches too short. it just barely fit so I could turn the wheel. it was not in far enough to make me feel safe so I am believing that mine has been collapsed at some point from a tree hit or the like.
Now could anyone tell me what the lenght of a stock one is. I Measured mine and got about 31-32 inches. A new Borgeson Adjustable Steering Shaft goes from 31 3/4 collapsed to 38 1/2 extended. thats what i am thinking about replace it with. Any help is greatly appreciated!
Thanks , Matt
1979CJ7 is offline   Reply With Quote
Old 01-04-2007, 02:42 PM   #2
bigjoe
1977 CJ7
From what I've read Jeep stock steering is so so after awhile. Not so much the colum but shaft between colum and box. The little u-joints go bad. If I had the coin and was redoing the steering as you're doing I would replace all parts with a Borgeson setup from colum to shaft. Just my opinion. Goodluck
bigjoe is offline   Reply With Quote
Old 01-04-2007, 03:06 PM   #3
1979CJ7
1979 CJ7
Where is there a Borgeson Column? i only see a flaiming river one and i am sure not going to buy that... way too much... i think im just going with the steering sharft.
Still anyone know the length of the stock one? Just to see if its compressed
Old 01-04-2007, 05:18 PM   #4
bigjoe
1977 CJ7
I have a catalog from them that I thought had one in it. I maybe wrong. I'll check and see.
Old 01-04-2007, 06:27 PM   #5
1979CJ7
1979 CJ7
ok thanks man!
Old 01-04-2007, 06:39 PM   #6
GPER
1979 CJ7
If you just took the shaft out, replaced the steering box the shaft should go back in. Do you have a body lift or after market frame???????? Anyway the Bourgeson is a nice shaft.
GPER is offline   Reply With Quote
Old 01-04-2007, 09:44 PM   #7
1979CJ7
1979 CJ7
that was my assumption. i figured it would go back in but i measured it and it was 31.5 to 32 inches in length. i figured i needed about 34-35 inches to make me happy.
the front of my frame is hacked together but to my knowledge its stock. If i have a body lift its only 1 inch but i am not sure on that as well either.
i see the new shaft in my future. I really wanted to see if it was collapsed or it was something else.
Old 01-05-2007, 07:26 AM   #8
nasd
I have 2 steering columns in my shed. From the floor to the top they measure 35 1/2" and 36". I can't easily get to them to tell you how long they are without them sitting on top of the steering wheel.
nasd is offline   Reply With Quote
Old 01-05-2007, 08:05 AM   #9
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Might want to check eBay and type in "jeep steering shaft". I'm at work now so I can't access eBay to do the link. Anyway, there's a guy selling Crown Shafts with needle bearing ujoints on both ends. I put one in my CJ5 3 years ago and it's still as tight as the day I bought it. Definately worth the $130 I paid. Its slip joint was easy to extend/collapse too.. unlike the stock setup. If nobody posts up the length by the time I get home from work, I'll measure and post the length to my 80 CJ5 with power steering and non-tilt column.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 01-05-2007, 09:18 AM   #10
Mud Machine
Jeep Addict
Mud Machine's Avatar
Here's an eBay link to "Jeep Steering Shaft"
http://search.ebay.com/search/search.dll?cgiurl=http%3A%2F%2Fcgi.ebay.com%2Fws%2 F&fkr=1&from=R8&satitle=jeep+steering+shaft&catego ry0=&submitSearch=Search
GR8 Half Top Conversion Thread
Does your gas tank overflow at the pump?
SUBMIT FORMAL COMPLAINT HERE!
2005 Rubicon LJ Unlimited - 4 1/2" BDS Suspension - 285/75/16 Toyo M/T's - 12,000# Winch - Ground Pounder Fab Rear Bumper - FabRieckAtions Custom Front Bumper - Overkill Engineering Tube Fenders - GR8 Half Top - Rock Hard Cage - Banks Monster Exhaust - 5.13 Gears - High Performance Flux Capacitor
1976 CJ-7 - 33" Super Swampers - BDS 4" Suspension - 6 Point Roll Cage
Mud Machine is offline   Reply With Quote
Old 01-06-2007, 08:45 PM   #11
bigjoe
1977 CJ7
Checked on that catalog. Mullins is a div. of Borgeson that makes columns. Mostly for hot rod applications though. Catalogs are a few years old so prices are off. If you think that column is ok swap-out shaft and call it a day. Goodluck.
Old 01-06-2007, 08:58 PM   #12
fromme
www.summitracing.com also carries the borgeson shafts. I believe they stock them, it's where I got mine.
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline   Reply With Quote
Glock Forum
