Stock Looking CJ's - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Stock Looking CJ's
Bds fox ipf 2.0 racing series shocks now available at rockIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete
Unread 11-24-2012, 10:26 AM   #31
roboto65
1976 CJ5
Originally Posted by GlennLever View Post
Two suggestions.
Get the factory service manual (bible for any Jeep project)
Post your questions here
1st part Check I collect them heck I have shelves of Manuals
2nd Did they all come with graphics wiki show alloy wheels also what did they look like ?
There is a hole on the back fender down low I assume that is for a running light that is missing.
roboto65 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 10:35 AM   #32
GlennLever
GlennLever's Avatar
Post a picture of the hole, I can not help with the other questions, someone else?
Glenn R. Lever
Rochester, New York 14617-2012
My Cars http://www.leverfamilysite.com/vehicles.htm
My restoration thread here on the Jeep forum
http://www.jeepforum.com/forum/f8/cj...build-1269301/
New FED, Drag Racing Forum (I am an Administrator) at
http://www.frontenginedragsters.org/forum/index.php
GlennLever is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 11:22 AM   #33
Pathkiller
1974 CJ5
Here's my 74 CJ5 after a frame off restoration. Overall theme is "restomod", upgraded and modernized components while trying to maintain a look as close to stock and old school as possible. It has a rebuilt 258 with 4.0L head, HEI, header, 2bbl MC2100 carb, power steering, power disk brakes, T176 4-speed and D300 T-case.
74 CJ5 complete frame off restoration
Pathkiller is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 12:22 PM   #34
xjandyj
pathkiller, we really got to get together at some point........
mostly stock 2a..
11"brakes
rollbar
sears hubs
bunch of little stuff...
repainted orig color
xjandyj is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 01:55 PM   #35
keith460
Jeep. There's Only One
keith460's Avatar
Now that's what I'm talking about!
Same looks as the original with more modern components.
Love the look of the white stamped steel wheels against the green color. Really makes it stand out.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 04:00 PM   #36
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
mostly stock 2a..
11"brakes
rollbar
sears hubs
I must get one of these! My Dad had a '48 CJ2A before I was born. I think he'd like it if I got one to restore as long as it wasn't too far gone or money pit. I may even be able to get him to help! Gotta get my CJ7 done first though.
I know there's a picture of the 2A around here somewhere. I'll try and find it and scan it. Edit: yup here it is: I'm not sure if there are more pictures of it or not but I'll keep looking
'85 CJ-7 Laredo currently under construction.
My Rebuild/Restoration Thread, In Progress
BlkCJ7Laredo is online now   Reply With Quote Quick reply to this message
Unread 11-24-2012, 04:17 PM   #37
Jon In Tucson
Jesus Is Lord!
Jon In Tucson's Avatar
1983 CJ5
Not as pretty as you guy's, but I have a lot of fun...
Here is my mostly stock/original 1983 CJ5:
258CI
T176
Dana 300
Dana 30 and AMC 20 differentials.
The seats have been replaced with some inexpensive ones from Rugged Ridge. The paint is original, Nassau Beige, buffed out for some luster, but the decals are faded and I have lots of pin striping courtesy of the AZ desert. Facing the annual frustration of the BBD and AZ emissions, I installed the Junk Yard TBI. In the motor picture you see the throttle body, and I have installed the GM ignition module as well as the knock module on an aluminum flat bar for a heat sink. I modified the duraspark distributor to accommodate the Chevy 7 pin module so the ECM controls both fuel and spark. PO replaced the 2 piece axles with Mosers. The wheels are original white 15X7 with the black pinstripe. They are encased by 31X10.50's. God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 05:06 PM   #38
diddy2003
Woah. That is very cool! Great job. The wheels are sweet!
diddy2003 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 08:58 PM   #39
VooDoo2
1978 CJ7
My 78 CJ7 Levi Edition (RHD Australian delivered) List particulars
Year & Model...........11978
Engine....................258
Transmission............T400
Transfer Case..........Quadratrac
Front Axle...............Dana 30
Rear Axle................AMC 20 one piece axle
Stuff you just could not leave alone
Suspension..............Stock
Steering..................HD Steering Shaft, Power steering conversion
Ignition...................HEI Dizzy
Cooling...................Stock
Heater....................Removed
Valve Cover.............Stock
Carburetor...............Holly
Headlights...............Direct battery voltage with relays
VooDoo2 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 10:58 PM   #40
GlennLever
GlennLever's Avatar
Our second Australia entery after
019...gazzo................http://jeepspace.jeepforum.com/gazzo..............Fremantle, Western Australia
See
http://www.jeepforum.com/forum/f8/st.../#post14493909
Glenn R. Lever
Unread 11-25-2012, 02:11 AM   #41
gazzo
Originally Posted by Bobs85Reny View Post
Here is mine. I am making changes. Going back to the stock rims. Just got some new meats for them. Original paint except hood. Engine fire. Upgraded to a Howell TBI system. Stock suspension even have a whitco orig top
That will be awesome bob. Just wish I'd thought about asking the lady I bought mine from for books, paperwork and such.
Gary (gazzo)
http://www.jeepforum.com/forum/f8/gazzos-cj10-truck-2185617/
gazzo is offline   Reply With Quote Quick reply to this message
Unread 11-25-2012, 03:56 AM   #42
gazzo
Very nice, I want your wheels and center caps!
Yeah, what Glenn said, I got the rims but what's up with the centres? They are way shiney like noo. I want some of those!
Gary (gazzo)
Unread 11-25-2012, 08:33 AM   #43
deforg
1982 CJ7
Hey Gazzo, Do you have the white overlander still?
I'd love to see it up here.
1982 CJ7
258 w/ 5spd
54,000 original Miles
People I dislike:
know-it-all [noh-it-awl]
1. a person who acts as though he or she knows everything and who dismisses the opinions, comments, or suggestions of others.
deforg is offline   Reply With Quote Quick reply to this message
Unread 11-25-2012, 09:41 AM   #44
mvigo
mvigo's Avatar
Originally Posted by keith460 View Post
1984 Jeep CJ-7 Renegade
Color: Sebring Red (3B)
Interior: Denim Black (original seats replaced)
Engine: I6 258 (MSD Ignition & Weber 32/36 carb)
Transmission: Borg-Warner T5 (original a T4)
Transfer Case: Dana 300
Suspension: 3" Black Diamond
Front Axle: Dana 30 (4.10 open)
Rear Axle: AMC 20 (4.10 open/2 piece axles)
Wheels: OEM White Wagon Wheel (w/original black pinstripe)
Tires: 32" BFG All-Terrain (5ea.)
Options: Renegade Package (includes Decals, Convenience & Decor Group), Power Brakes, Power Steering, Tachometer and Clock, 3.31 axle ratio (now 4.10), Locking Center Console, AM/FM Stereo Radio, Tilt Steering Wheel, Carpeting (gone), Soft Top w/Hard Doors (gone), Spare Tire Lock, Side Steps (were body colored, now black)
Keith,
Son of a gun, everytime I see your completed CJ I gaze in wonderment!
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline   Reply With Quote Quick reply to this message
Unread 11-25-2012, 10:30 AM   #45
mvigo
mvigo's Avatar
Year & Model...........1985 CJ7
Transmission............T-5 with Hurst shifter
Transfer Case..........Dana 300 with Teralow 4:1
Front Axle...............Dana 30 with Detroit Truetrac
Rear Axle................AMC 20 one piece axle with Detroit Truetrac
Interior...................Line-X'd tub
Exterior...................Hard top, hard doors, bikini top
Paint color................original paint, Ice Blue Poly, paint code 4C
Misc.......................Tuffy console and storage trunk, onboard air, Superwinch, dual batteries
Stuff you just could not leave alone:
Suspension..............2.5 Rubicon Express Extreme Duty, 1" body lift, Crabtree shackle hangers
Steering..................Sam's offroad steering box bracket
Cooling...................4 core radiator
Heater....................Blower Motor Upgrade
Valve Cover.............aluminum valve cover
Fuel Injection...............MOPAR
Headlights...............Direct battery voltage with relays, KC Driving lights added
Grounds..................dedicated grounding posts front and rear
Dash......................stock
Radio......................AM/FM/CD with iPod jack and CB
how she sits now with top/doors on:
without tops/doors:
engine bay:
going down Cadillac Hill on the Rubicon Trail:
how she sat the 1st 7 years I had her:
