Stock Gear Ratio on a 83 CJ-7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Stock Gear Ratio on a 83 CJ-7
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 04-24-2008, 06:08 PM   #1
jeff83
What would be the stock gearing for a 83 CJ-7. Like 3.07?
jeff83 is offline   Reply With Quote
Unread 04-24-2008, 06:09 PM   #2
brussell
1983 CJ7
I had 2.73's..that sucked..
brussell is offline   Reply With Quote
Unread 04-24-2008, 06:15 PM   #3
ReconRabbit
1983 CJ7
Mine too......
If your Jeeps not leaking it's out of fluids.
ReconRabbit is offline   Reply With Quote
Unread 04-24-2008, 06:22 PM   #4
limegreenCJ7
look on your rear axle...
to the right of the diff cover
there'll be two capital letters
DD and its 2.73
I'm not sure the other codes
limegreenCJ7 is offline   Reply With Quote
Unread 04-24-2008, 06:39 PM   #5
SuB8HaVeN
I have 3.31s from the factory. I don't like them, but I don't hate them.
http://www.jeeptech.com/axle/amc20.html
You can use those codes to ID your rear end, and hopefully your front end has the same gear ratio. Of course you never really can tell if the PO has swapped gears. I hopped into a CJ-7 one time that had the markings for 2.73 and you couldn't let off the clutch without spinning the tires in that thing, so it must have been running 4.10 or 4.56 most likely.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline   Reply With Quote
Unread 04-24-2008, 06:50 PM   #6
jeff83
Alright thanks for the help guys. Just one more question would 4.10's be good for 34x10.5x15 LTB's?
Unread 04-24-2008, 07:49 PM   #7
brussell
1983 CJ7
4.10's with a DANA 300 and a 4.1 1st gear will work mostly but I find myself wishing I had a t18(or some other 6.1 granny gear sometimes). NVG4500 would be best. Then you could go 4.56 w/a 4.1 DANA 300 and still hit 65 mph
Unread 04-24-2008, 07:59 PM   #8
jeff83
The only problem with that is i just swapped out a t-4 for an SR-4
Unread 04-24-2008, 10:19 PM   #9
only in a jeep cj
Sorry, you went backwards in the transmission chain.....
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote
Unread 04-25-2008, 06:16 AM   #10
jeff83
Yeah i no it was cheap
Unread 04-25-2008, 07:10 AM   #11
SuB8HaVeN
If you ran 4.10 gears, in 4th gear you would need to turn 2400-2500RPM to do 60mph, and about 2600-2700RPM to do 65mph.
Unread 07-18-2012, 06:32 PM   #12
papajeep60
1981 CJ8
CJ axle ratio codes
Check out this web site for Jeep Axle codes:
papajeep60 is offline   Reply With Quote
