Stock fuel pump question - JeepForum.com
post #1 of 5 Old 12-18-2007, 08:30 AM Thread Starter
jennandal
1983 CJ5
Okay, you guys know the stock fuel pump has the metal fuel line coming up and over the valve cover at which point a rubber fuel line runs to the fuel filter and on and on. Well, in the process of doing my head swap I creased the dang thing and it leaks about six inches or so up from the fuel pump. What is the best thing to do?? Should I use pipe cutters and cut the metal fuel line before the crease and run rubber line from there? Or replace the metal line altogether? Or does it matter? Cause if it doesn't matter I'll cut the metal fuel line and replace with rubber.
83 CJ5 w/258 I6, 4.0 HO head swap, Weber 34 w/ nutter bypass, 2.5" shackle lift w/8* castor shims, superlift shocks, 32" Hankook Dynapro MT's, TFI ignition upgrade and coil, dual electric fan off full size Dodge pickup, and tons of wires and vacuum hosing laying around.
jennandal is offline
post #2 of 5 Old 12-18-2007, 09:51 AM
fatterman
fatterman's Avatar
yes you can cut the fuel line and replace with rubber.
fatterman is offline
post #3 of 5 Old 12-18-2007, 09:55 AM
OldSailor
1977 CJ7
Yes, you can cut the metal line and get a longer ruber line. Just make sure your new rubber line is made for fuel systems, and that it's not vacuum line.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline
post #4 of 5 Old 12-18-2007, 10:52 AM
biozombie
You could also spend $5 on a length of steel tubing at the parts store, and bend a new metal hard line exactly where you want it. You should keep your amount of rubber hose to a minimum because it deteriorates over time. A cheap tube bender should be $15-20.
biozombie is offline
post #5 of 5 Old 12-18-2007, 01:03 PM
cottontop
It does not hurt to cut the metal line and run rubber hose just make sure that it for fuel and route where it does not rub or get too hot. Yeah its something else to change but its a simple fix if you wanted to go the cheap way...
84 Cj-7 with hard top and hard doors that is regaining life as a jeep again
cottontop is offline
Stock fuel psi for electric fuel pump??? TampaXJ Jeep CJ Forum 26 08-30-2010 01:58 PM
Fuel pump question BeesJeep Jeep CJ Forum 6 11-25-2008 04:29 PM
258 fuel pump Question JoonHoss Jeep CJ Forum 14 04-13-2007 08:13 AM
Dumb fuel pump question tmak504 Jeep CJ Forum 10 06-07-2006 07:45 AM
Quick Question about the fuel pump. MY_CJ_AND_ME Jeep CJ Forum 1 11-21-2005 07:01 PM
