Stock D30 drag link length etc? - JeepForum.com
post #1 of 9 Old 07-02-2013, 07:03 PM Thread Starter
jeepwhore
Im in need of two measurements. The distance between the upper ball joints (c-c) and the length of a stock drag link (c-c of the tre's)
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #2 of 9 Old 07-02-2013, 07:19 PM
MoC
Narrow or wide trac?
Dark here, can measure tomorrow if needed.
MoC is offline
post #3 of 9 Old 07-02-2013, 07:21 PM
jp360cj
1977 CJ7
WT or NT? are you just looking for a ballpark figure for running length or collapsed& extended measurements?
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #4 of 9 Old 07-02-2013, 07:34 PM Thread Starter
jeepwhore
Oops, sorry guys. WT lengths please. And for the drag link, looking for as close a measurement as possible to running length.
Trying to get a DOM drag link made but my steering box isn't mounted. Need the ball joint measurement to compare to the distance between trunion bearings on my yota axle so I can see if I need to add or subtract any length for the difference between the two axles.
post #5 of 9 Old 07-02-2013, 07:40 PM
robs7
1983 CJ7
My drag link measures 29-1/4" grease fitting to grease fitting. Rob
robs7 is offline
post #6 of 9 Old 07-02-2013, 07:46 PM Thread Starter
jeepwhore
And that's a WT axle? Awesome, thanks!
Just need the ball joint measurement now.
post #7 of 9 Old 07-02-2013, 08:06 PM
robs7
1983 CJ7
Yes that's wide track. It's lifted but everything is parallel and pretty well aligned. I will go get the ball joint measurement for you. Rob
robs7 is offline
post #8 of 9 Old 07-02-2013, 08:11 PM
robs7
1983 CJ7
43-5/8" c-c on the upper ball joints. Rob
robs7 is offline
post #9 of 9 Old 07-02-2013, 08:50 PM Thread Starter
jeepwhore
Awesome, thanks!
