stock computer under dash necessary? - JeepForum.com
post #1 of 13 Old 08-09-2013, 09:20 AM Thread Starter
I6CJ7
My 4.2 CJ has been nuttered for years, and recently i stripped the interior for line-x. Currently the computer under the dash is sitting on floorboard. Is this thing necessary or can i unplug it and remove it?
I6CJ7 is offline
post #2 of 13 Old 08-09-2013, 09:38 AM
Jeeprage
Jeeprage's Avatar
Unplugging it should be fine. I'd unplug, try to start it and check that reverse lights work.
2015 JKU - 6m
Jeeprage is offline
post #3 of 13 Old 08-09-2013, 09:52 AM Thread Starter
I6CJ7
Hah, ok sounds good to me. Its just an extra 2 pounds i dont need hopefully.
I6CJ7 is offline
post #4 of 13 Old 08-09-2013, 12:31 PM
capt205
1983 CJ7
If its nuttered , isn't it bypassed anyway? At least that's how I understand the mod.
capt205 is offline
post #5 of 13 Old 08-09-2013, 02:55 PM Thread Starter
I6CJ7
Well there's 2 computers, one is on the driverside fenderwell. Which gets removed with the nutter bypass. But i don't know about this one. I was thinking maybe it still had power wires going in and out of it that still powered other things like the dash?
I6CJ7 is offline
post #6 of 13 Old 08-09-2013, 03:27 PM
jeepwhore
You've got that backwards. The nutter takes the computer under the dash out of the equation. The ICM on the drivers fender is still required whether it's nuttered or not (unless you did a stealth HEI and/or team rush upgrade as well)
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #7 of 13 Old 08-09-2013, 03:28 PM
lucdog
lucdog's Avatar
1980 CJ5
Close, but not quite. The ICM on the dr. Fender controls spark and is needed, unless. A stealth HEI, MSD box, or HEI Distributor is used. I wouldn't call it any kind of computer.
I believe what the OP is asking is the box above the glove box, behind the dash. This is the one the Nutter bypass does away with. Neither of the 2 have anything to do with anything on the dash.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 13 Old 08-09-2013, 04:39 PM Thread Starter
I6CJ7
Lol ok, yeah I'm an HEI dizzy. Thanks for the help guys, good to know i can pull that useless computer out.
I6CJ7 is offline
post #9 of 13 Old 08-09-2013, 06:55 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Anyone have one of those ECM brackets from their heater ducting they aren't needing? Would like to put one under my dash for the future 5.0L swap... I've read those are the same size as the Ford EEC-IV modules.
Rick
Cutlass327 is offline
post #10 of 13 Old 08-09-2013, 11:48 PM Thread Starter
I6CJ7
Huh, cool
I6CJ7 is offline
post #11 of 13 Old 08-10-2013, 04:47 AM
86cj74.2L
86cj74.2L's Avatar
What are you doing with the dash computer?
86cj74.2L is offline
post #12 of 13 Old 08-10-2013, 05:43 AM
dg6772
That bracket also works for the obd 1 pcm for a chevy conversion. Just sayin'
Dave in Muskegon
dg6772 is offline
post #13 of 13 Old 08-10-2013, 09:14 AM Thread Starter
I6CJ7
Probably just set it with the rest of my CJ stuff in the basement.. I have almost enough spare front and back seats from multiple CJ's to create a theatre down there!
I6CJ7 is offline
