Stock CJ7 fold & tumble rear seat question - Page 2 - JeepForum.com
post #16 of 43 Old 06-23-2013, 09:38 AM
keith460
Jeep. There's Only One
keith460's Avatar
I've seen the carpet on rocker panels before for the Limited models but never the aluminum strips for the hardtop.
1984 CJ-7 Renegade
keith460 is offline
post #17 of 43 Old 06-23-2013, 10:35 AM
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
Originally Posted by keith460 View Post
Must have been added by a PO? Never seen that before on a CJ-7 hardtop.
Would you know the exact location of the hook for the seat strap?
Measuring from the first hole for the hardtop by the door opening, the first hole for the hook is 7 3/4" on center back from the hardtop hole. The holes on the hook are 1" OC.
'85 CJ-7 Laredo currently under construction.
BlkCJ7Laredo is offline
post #18 of 43 Old 06-23-2013, 05:35 PM Thread Starter
bruin211
Originally Posted by BlkCJ7Laredo View Post
Here's the strap and hook setup. The strap ISN'T the same as on the doors. It is looped on both ends, 1" wide and 13" long. What I find strange is this 1985 Renegade has aluminum strips that the hook is attached to and go onto the hardtop before the bolts go in.
Yes, thanks for posting the picture of the strap and for the dimensions. Is it permanently attached to the seat support at all or is it removable?
bruin211 is offline
post #19 of 43 Old 06-23-2013, 08:08 PM
BlkCJ7Laredo
It's all removable. As you can see where it goes around the the seat bump screw the loop is sewn big enough to fit over the end of it so you can remove it and put in the glovebox if you'd like.
post #20 of 43 Old 06-23-2013, 08:26 PM
1986cj
Sorry it took so long. Selling my house and moving so my CJ was not easy to get to, but this is out of my 1986 Owner's Manual.
1986cj is offline
post #21 of 43 Old 06-23-2013, 08:31 PM
keith460
keith460's Avatar
Nice info, never seen that before.
1984 CJ-7 Renegade
keith460 is offline
post #22 of 43 Old 06-25-2013, 10:35 AM
Oily
Originally Posted by JrTjK View Post
I always wondered what that thing was for....makes sense! Thanks for sharing
Me too, and, I was always wondering about a good way to keep the seat folded/tumbled. Great topic.
While we are at it, how does the flip down windshield stay down/ not bounce ?
I have a strap on the inside of my windshield with a click buckle. Sewn on and I am sure it is stock. I don't have the hood anchor point. How does it work ?
I should say that I do have the metal bracket which something else should secure it to the hood.
Oily is offline
post #23 of 43 Old 06-25-2013, 11:11 AM
wm69
Factory strap didn't have a click buckle, it had a canvas strap with a metal buckle on it you loop the strap back through. Hood has a footman loop right in the middle that you run the strap through.
wm69 is offline
post #24 of 43 Old 06-26-2013, 09:30 AM
lugnut28
lugnut28's Avatar
Seeing I can't view 1986cj's photo (iPad and iPhone says connection error PC says I'm forbidden) and I can't upload a picture from my 1985 manual, I guess I'll just have to wait until they get this whole picture thing straightened out
lugnut28 is offline
post #25 of 43 Old 06-26-2013, 10:39 AM
Oily
Like a motorcycle chin strap ?
Oily is offline
post #26 of 43 Old 06-26-2013, 12:00 PM
wm69
If you're referring to the strap from windshield frame to hood, then yes.
wm69 is offline
post #27 of 43 Old 06-30-2013, 08:32 PM
lugnut28
lugnut28's Avatar
This is what it looks like in my 1985 manual.
lugnut28 is offline
post #28 of 43 Old 07-01-2013, 07:38 AM
keith460
keith460's Avatar
That's a little different from the 86' manual. 1985 looks as if they want you to loop it around the seat belt anchoring point on the roll bar.
Was there a permanent strap bolted behind the seat belt for 1985? If there was, I guess people complained about the strap blowing around while driving the Jeep without a top so AMC moved it to loop on the seat foot bumper and then to attach it to a hook on the tub.
I'll have to research the Parts Manual a little bit to see.
1984 CJ-7 Renegade
keith460 is offline
post #29 of 43 Old 07-01-2013, 07:54 AM
keith460
keith460's Avatar
Since I have no holes for any type of top, can I get a measurement from the vertical body seam of the tub side panel-to-rear corner panel instead?
1984 CJ-7 Renegade
keith460 is offline
post #30 of 43 Old 07-01-2013, 08:15 AM
lugnut28
lugnut28's Avatar
I thought it would be flapping in the wind too. I went to my Jeep dealer and he gave me the name of two dealerships that still had straps so I bought them both. Ill post a picture when they show up. I took a picture of my parts manual of the strap i think i'm getting. On my 85 the measurements from the corner seam to the holes are 30 1/16 and 31 1/8.
lugnut28 is offline
