Stock Carburetor on a 77 cj5 - Page 3 - JeepForum.com
post #31 of 36 Old 09-18-2012, 01:50 AM Thread Starter
Sammycj5
1977 CJ5
Originally Posted by FrnchDp View Post
you got a few options if you're going new. most here will tell you to get a weber or motorcraft carb as they are known to be better all around than the carters. I just swapped out my carter BBD to a Motorcraft 2150.
what's your budget for a replacement carb?
also, many here will also tell you that a rebuild kit isn't a bad thing, and mostly goes bad if it's not done properly.. but no need to tell your pops ; )
500 is to much so i guess round 400 and down maybe.
Sammycj5 is offline
post #32 of 36 Old 09-18-2012, 07:35 AM
FrnchDp
FrnchDp's Avatar
I paid under 300 for my motorcraft. you can find webers for around that as well.
Here's the guy I got mine from (if you chose the Motorcraft) -> http://www.ebay.com/itm/NEW-MotorCra...0&cmd=ViewItem
Many members have also purchased from this guy. Many others have purchased the Weber 38, and they can provide you a link to where they got theirs if you want to look into that instead.
1986 CJ-7 - I6-258
2000 WJ Limited - V8-287
FrnchDp is offline
post #33 of 36 Old 09-19-2012, 12:11 AM
86cj74.2L
86cj74.2L's Avatar
A remanufactured BBD will cost anywhere from 380 to 550 dollars. Napa being most expensive, but remanufactured by Holley.
86cj74.2L is offline
post #34 of 36 Old 09-19-2012, 02:44 AM
BagusJeep
1981 CJ7
A kit will run you about $30 and include all the gaskets, some of the little bits and fasteners and an instruction manual. They are quite easy to work on, a fine carb in its day fitted to many vehicles, and it is rewarding to take a piece of old junk and make it work.
Now that is not saying that a shiny piece of Gucci kit like a Weber is not good. It is a great manufacturer. I have a Weber 40 from a Ferrari Daytona gracing Puthijeep's manifold and it is F A B. However it is not $30.
Bagusjeep has a 1981 Carter BBD non controlled which has been stripped, cleaned, adjusted and reassembled with new genuine paper gaskets (cut out with my penknife from real paper). The total rebuild cost $5 but it took 3 tries to get it to run right with float levels, idle tubes and inlet valve all needing some study. It has been fine for the last 4 years.
If the BBD did NOT have worn throttle shaft bushings (give that throttle shaft a wiggle, any sideways movement is an air gap that will make idle difficult to adjust) you may find that the best bangs per buck sit with trying a rebuild. For $30 it will at least give you a spare carb.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #35 of 36 Old 09-19-2012, 03:25 AM
86cj74.2L
86cj74.2L's Avatar
And there are a few of us on here capable of replacing the bushings..........
post #36 of 36 Old 09-19-2012, 01:43 PM
scooter71954
2016 JK Wrangler
don't forget to check the gasket surfaces for flatness. A warped body will allow vacuum leaks that will drive you crazy. I once purchased a 74 VW bus with twin carbs in 1984. I would run fantastic until it heated up. It drove me crazy! Then, on my fourth carb rebuild I used a Browne & Sharp rule (known for precision) and could see light under the rule due to carb body warpage. I used some float glass and grinding compound to flatten all the surfaces. Result? Perfect, never had another problem for the remaining 5 years I owned it.
Now, I always check those surfaces and fix any deviations when rebuilding a carb.
This is not a restoration! My goal is stop the rust, mechanically sound and easy on the pocketbook.
scooter71954 is offline
carb
Carburetor? qvfd153 Jeep CJ Forum 17 09-26-2012 09:26 AM
New carburetor Pinny1995 Jeep CJ Forum 4 07-18-2012 04:34 PM
304 v8 stock carburetor question/advice houstonmat Jeep CJ Forum 14 02-02-2012 12:43 PM
Which Carburetor? jamest1234 Jeep CJ Forum 9 09-08-2009 04:12 PM
Carburetor martin10 Jeep CJ Forum 11 06-05-2008 10:09 AM
