Stock Carburetor on a 77 cj5 - Page 2 - JeepForum.com
post #16 of 36 Old 09-15-2012, 10:09 PM Thread Starter
Sammycj5
1977 CJ5
did that work? its a carter.
Sammycj5 is offline
post #17 of 36 Old 09-16-2012, 08:56 AM
CSP
That's a Carter YF one barrel.
CSP is offline
post #18 of 36 Old 09-16-2012, 10:07 AM
FrnchDp
FrnchDp's Avatar
so.. are you looking to replace the whole thing? rebuild it? bring it back to stock?
1986 CJ-7 - I6-258
2000 WJ Limited - V8-287
FrnchDp is offline
post #19 of 36 Old 09-16-2012, 10:22 AM
james04si
james04si's Avatar
1977 CJ5
Wow if that's a carter YF then they must have changed it quite a bit because mine looks nothing like those pictures.
james04si is offline
post #20 of 36 Old 09-16-2012, 10:47 AM
james04si
james04si's Avatar
1977 CJ5
Yeah just to make sure I went back to some pictures of my old 232. The YF defenatly doesnt look like that. The YF looks like
That carburator looks more like what I pulled off the 258 I rebuilt which I assume was the carter BBD non feedback, not 100% sure since I didnt use it or rebuild it but it is defenatly a 2 barrel that looks like this
post #21 of 36 Old 09-16-2012, 12:39 PM
FrnchDp
FrnchDp's Avatar
I know the BBD has the bowl vent port. Does the YF? That seems to be the biggest difference I notice.
1986 CJ-7 - I6-258
FrnchDp is offline
post #22 of 36 Old 09-16-2012, 12:54 PM
86cj74.2L
86cj74.2L's Avatar
I'd say it's the older non feedback BBD.
Looks like the old choke style too. ( non electric) And I can't tell from pictures but it looks not to be hooked up......
86cj74.2L is offline
post #23 of 36 Old 09-16-2012, 01:33 PM
james04si
james04si's Avatar
1977 CJ5
Yes the YF has a bowl vent. It's built into the top half of the carb not like the plastic on the BBD. You can see it in my picture of the YF.
Actually in my picture its the nipple with the white cap on it. I didn't have it hooked up to the carbon canister for about a year. Suprisingly it ran just fine.
post #24 of 36 Old 09-16-2012, 02:54 PM Thread Starter
Sammycj5
1977 CJ5
not bringing it back to stock, my father refuses to let me buy a rebuild kit because he says they never turn out right, so i guess im looking to replace it from what i have looked up its a carter 2425, which is a 2 barrel from what i've read..
Sammycj5 is offline
post #25 of 36 Old 09-16-2012, 02:58 PM Thread Starter
Sammycj5
1977 CJ5
Originally Posted by james04si View Post
that is what it originally looked like before we put a bigger air filter on it.
Sammycj5 is offline
post #26 of 36 Old 09-16-2012, 03:09 PM
james04si
james04si's Avatar
1977 CJ5
I ended up putting a Howell TBI on mine. A bit more than a carb but it starts and runs perfectly in all weather no need for it to warm up on cold days.
post #27 of 36 Old 09-16-2012, 04:28 PM Thread Starter
Sammycj5
1977 CJ5
Heres more pictures of the carburetors..
180-144
Sammycj5 is offline
post #28 of 36 Old 09-16-2012, 06:45 PM
FrnchDp
FrnchDp's Avatar
you got a few options if you're going new. most here will tell you to get a weber or motorcraft carb as they are known to be better all around than the carters. I just swapped out my carter BBD to a Motorcraft 2150.
what's your budget for a replacement carb?
also, many here will also tell you that a rebuild kit isn't a bad thing, and mostly goes bad if it's not done properly.. but no need to tell your pops ; )
1986 CJ-7 - I6-258
FrnchDp is offline
post #29 of 36 Old 09-17-2012, 10:06 AM
John Strenk
John Strenk's Avatar
1976 CJ5
certainly a BBD carb. Rebuild kits are cheap and a lot cheaper than a Weber.
Most rebuild go bad when you loose a part or forget to set something.
Sometimes the throttle bushings go bad and you need to get them replaced.
If you are going to buy a new one then the price difference between a Weber and Carter is not that much.
John Strenk is offline
post #30 of 36 Old 09-17-2012, 05:35 PM
86cj74.2L
86cj74.2L's Avatar
And webers are not always "plug and play" after installation. Plenty of people here to help get it set up correctly.
carb
Carburetor? qvfd153 Jeep CJ Forum 17 09-26-2012 09:26 AM
New carburetor Pinny1995 Jeep CJ Forum 4 07-18-2012 04:34 PM
304 v8 stock carburetor question/advice houstonmat Jeep CJ Forum 14 02-02-2012 12:43 PM
Which Carburetor? jamest1234 Jeep CJ Forum 9 09-08-2009 04:12 PM
Carburetor martin10 Jeep CJ Forum 11 06-05-2008 10:09 AM
