stock backspacing on my 86 - JeepForum.com
post #1 of 4 Old 03-12-2010, 07:33 AM Thread Starter
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
Hey guys, what is the stock backspacing on a wheel on an 86 CJ7? I read a few pages on how to measure it and I just want to double check cause I've never done it before.
Also, I need to widen my stance and I'm getting new rims.. is 2" on each side too much to move it out?
Thanks!
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #2 of 4 Old 03-12-2010, 07:56 AM
Mike Romain
My CJ rims have the numbers stamped into the back side of them, maybe have a close look at the back side of the spare tire?
They did use different rims for different packages. My 86 chrome spoke laredo rims are 15x7, not sure of the backspace number, didn't need to remember it.
My rims fit perfect. My 33x9.5's fit perfectly even to my fender flares.
Mike
Mike Romain is offline
post #3 of 4 Old 03-12-2010, 08:05 AM Thread Starter
mmerlina
mmerlina's Avatar
Hmm ok well I will tell you what I'm up to. I want to go up to 35s with 15" steel black rims. I also want to kick my wheels out a few inches on each side because with the 4.5" lift i'd like to widen my stance. So I had 2 questions.
What should my backspacing be in order to do that?
How wide of a rim should I be on for a 35" 12.5 15" tire?
And who might be a good company to call to get the rims from? I can't seem to find somewhere that has a rim to match my criteria.
Mike
1986 Jeep CJ7 (
mmerlina is offline
post #4 of 4 Old 03-29-2010, 09:20 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
8" rim. 10" rims are not required until you get up into a 14.5" wide tire. Using them on a 12.5" results in a weaker bead, exposes the bead to more debris and obstacles, causes odd wear, and IMO looks stupid.
Being that you have a WT, backspacing about 4". I wouldn't go lower than that.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
CJ7 Stock wheel backspacing Chrisfol82 Jeep CJ Forum 1 12-27-2008 08:49 PM
What is the backspacing on stock 83-86 wheels? 243 Jeep CJ Forum 2 05-08-2008 05:49 AM
How much Backspacing? Maverick83 Jeep CJ Forum 10 09-06-2006 05:39 AM
Stock backspacing of CJ wheels? jeeponly Jeep CJ Forum 0 04-25-2005 11:24 AM
what is cj backspacing? 86lx Jeep CJ Forum 2 03-30-2004 04:56 AM
