Still looking for a v6 Dauntlas. - JeepForum.com
post #1 of 16 Old 08-24-2013, 12:02 PM Thread Starter
stretch66dog
1969 CJ5
Looking for a V6 225 Dauntlas motor. I live in Atlanta if anyone out there knows where I might be able to find one close please let me know
stretch66dog is offline
post #2 of 16 Old 08-24-2013, 02:47 PM
colojeepguy
1970 CJ5
You can also use a 231 from a RWD GM car.
"It's better to have loved and lost, than to live with a psycho the rest of your life"
colojeepguy is offline
post #3 of 16 Old 08-24-2013, 03:56 PM Thread Starter
stretch66dog
1969 CJ5
A 231 v6 would be nice but my 69 willy's came with the 225 and i'm trying to keep it stock. Still searching.
post #4 of 16 Old 08-24-2013, 04:04 PM
kovic
1983 CJ5
So you have the Dauntless 225 and looking for another? Or its no longer in your jeep?
kov
kovic is offline
post #5 of 16 Old 08-24-2013, 04:31 PM Thread Starter
stretch66dog
1969 CJ5
The block and internals has suffered catastrophic damage I need to replace the 225. It could be machined but I would have to spend major cash on internals to include new balanced crank, cylinder sleeves. Father didn't take care of the motor and it overheated at one time. Engine block is too unstable.
post #6 of 16 Old 08-24-2013, 04:41 PM
kovic
1983 CJ5
Dang so its not rebuildable?
kov
kovic is offline
post #7 of 16 Old 08-24-2013, 10:15 PM Thread Starter
stretch66dog
1969 CJ5
No that's why I'm looking for a replacement motor. The block is to weak fron heat damage and torn up fron engine particles from the over heating.
post #8 of 16 Old 08-24-2013, 10:18 PM Thread Starter
stretch66dog
1969 CJ5
I didn't overheat the motor. My 76 year old non mechanical inclined Dad did. I just got it and the first thing I did was a compression test....Epic fail.
post #9 of 16 Old 08-24-2013, 11:18 PM
CSP
Overheating the engine won't ruin it to the point where it can't be rebuilt. Failing a compression test is no substitute for an internal inspection either.
CSP is offline
post #10 of 16 Old 08-25-2013, 01:04 AM Thread Starter
stretch66dog
1969 CJ5
The motor has suffered a lot of damage from the heat and metal pieces floating in the motor. Neglected engine for sure. Main bearings are scorched and pitted.The block is to weak. Cast iron can become brittle as the rear main caps started fallen apart in pieces to include cam timing gear. Cylinders are tapered. Not going to chance it by spending loads of cash for machine work cylinder sleeves and all new intrrnals to include a new balanced crank. Die tested the block and it is shot with cracks and missing pieces of the block in the center. This has got to be one of the top 5 motors that I have seen over 23 years of rebuilding in this bad of shape. Still looking...
post #11 of 16 Old 08-25-2013, 01:16 AM Thread Starter
stretch66dog
1969 CJ5
The motor as one might understand is all apart and believe me it's toast. Dad ran motor without water & oil. Nor ever changing the fluids in 44 years. Overheating it and then added more oil. Jeep then sat for 7 years and then fired it up without checking the oil again! Yeah, as a retired U.S Army Apache helicopter mechanic I have seen it all and this right up there on the top 5 worse case's.
post #12 of 16 Old 08-25-2013, 11:17 AM
kovic
1983 CJ5
Well, now I am interested. Pics of the damage!
kov
kovic is offline
post #13 of 16 Old 08-25-2013, 07:54 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Might try the ECJ5.com page. They have a large V6 following.
jeepdaddy2000 is offline
post #14 of 16 Old 08-25-2013, 08:08 PM Thread Starter
stretch66dog
1969 CJ5
Thanks....
post #15 of 16 Old 08-25-2013, 09:24 PM
CSP
If you're doing any internet searches it would help to spell it correctly. It's Dauntless, not Duantlas.
Not trying to pick on your spelling, just noting that it could make the difference between finding one and not finding one.
CSP is offline
