Still having trouble - JeepForum.com
post #1 of 8 Old 01-20-2008, 11:41 AM Thread Starter
DannibusX
I've done a bit of work to my jeep this week but it's still running like crap at higher RPM. It kind of drops off, is this a timing issue? As far as I know it's supposed to be 8* BTDC. I plan on doing a nutter bypass in the coming weeks, and going with a DUI distributor, but I need it to run as well as it can until then as the jeep suddenly became my daily driver.
Thanks in advanced!
Dan
1986 CJ7, 4.2L I6, Carter BBD, Rancho 2.5" Lift, Team Rush.
Coming soon: Exhaust, Wheels and Tires, Axle Gearing.
DannibusX is offline
post #2 of 8 Old 01-20-2008, 11:53 AM
Mike Romain
With the computer still in there aren't you supposed to be setting the timing at 1600 rpm? There should be a sticker under the hood about this. I run about 9*.
I think you unplug the vacuum switches and unhook the distributor vacuum and plug this, then set the timing at 1600 rpm if I remember right.
Other than that a dirty distributor cap or even a dirty air filter and especially a dirty fuel filter can cause top end loss.
Mike
Mike Romain is offline
post #3 of 8 Old 01-20-2008, 12:33 PM
HighCountry
A bit of unasked for advice, the stock ignition is more reliable than the DUI stuff. Also, when (not if) it breaks you can get parts for the stock system at almost any backwoods hole in the wall parts place.
If you want to upgrade your ignition, which in my opinion is of little value you should do the 'Team Rush' version. Those parts are also readily available WHEN it breaks, plus you can change it back to stock with nothing more than a Phillips screwdriver in about 5 minutes.
Bruce
HighCountry is offline
post #4 of 8 Old 01-20-2008, 12:39 PM
80cj
80cj's Avatar
1980 CJ5
Bruce
DUI will use stock Chevy parts. I've used a stock Chevy module in mine no problem. It just doesn't have the coil saturation time as the DUI which is how DUI boosts the voltage output.
80cj is online now
post #5 of 8 Old 01-20-2008, 03:18 PM
kavephish
1981 CJ5
I have a 304 in mine and had the same issue. Idled/mid ranged fine, but stumbled badly at higher RPM. I have the MC2100 on it and turns out the float was too low. Bent up the float 1/4 inch and it ran fine after that. May want to check yours out.
kavephish is offline
post #6 of 8 Old 01-20-2008, 05:53 PM
Fjguercio
1978 CJ7
x2 Time at 1600 rpm. I went up 2 deg, then down 2deg at time a few times. Then when close tried at 1deg changes and settled on what was running the best. This helped me a lot.
x2 on the TEAMRUSH UPGRADE to Ignition or the FORD Ecoil change. HighCountry he did kinda ask... This is simple Adds add extra ground, Changed Cap w/brass terminals, rotar, new style plug wires and a used Ford Motorcraft Ecoil , $55 total and you got a great set up. A set up made for your engine.
I have been reading much this is good path!!!!! I am in the process now of this upgrade and have all the parts. I have read and been part of several threads and others in the past mo since dec 1. Look them up and print, there is about 5 of them excellent. Shows all the good points and bad points of the paths. I also strongly recommend you look at past threads.
JeepHammer showed us this article, VERY GOOD READ!!!
www.junkyardgenius.com/ignition/jeep/heicompair.html
Regards,
Fred
Fjguercio is offline
post #7 of 8 Old 01-20-2008, 06:17 PM
CJ Chet
X2! DUI is a souped up HEI. I have one and I love it! You CAN use the OEM module it just won't have near the power output, but it's an emergency fix.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #8 of 8 Old 01-21-2008, 04:54 AM
HighCountry
Fjguercio, I consider the 'team rush' upgrade to be 'stock' also due to fact that it uses commonly available stock parts! In my opinion, that is the way to go!
I have been around HEI since the begining and just don't care for them. That cumbersome cap/coil combo, plus the fact that if you don't carry a spare Rotor you will eventually have to walk home. I have come across countless '...it just died!" GM drivers whom had a bad rotor allowing the coil to fire THROUGH it directly to ground instead of firing the plugs. If you are around GM products after the late 80's you see that even THEY switched back to a separate coil.
In my world, Reliability/Simplicity is the NUMBER ONE consideration followed by Ease of Repair/Availability of parts as NUMBER TWO.
Bruce
cj5 trouble 8balls12 Jeep CJ Forum 4 10-15-2009 01:16 PM
Tie rod trouble zillla Jeep CJ Forum 8 07-07-2009 10:31 PM
Trouble when hot? BucketRider Jeep CJ Forum 2 04-16-2009 03:27 PM
trouble getting oil cap off jays83cj7 Jeep CJ Forum 2 01-07-2009 08:00 PM
hub trouble jeepster18_88 Jeep CJ Forum 1 02-01-2002 09:55 AM
