Stiff brakes - JeepForum.com
post #1 of 8 Old 08-13-2013, 09:16 PM Thread Starter
Jsdtm
Stiff brakes
Hi all. I am new to the forum and new to cj's. I recently purchased an 86 CJ 7 4.2 inline 6 automatic and my brakes are stiff and I have to mash them down HARD to get my jeep to stop. I don't have any leaks in my lines and I don't have the 8" disk on my MC, which from reading many posts I don't have a power booster. Is my MC bad in this case or anything else may be causing this? Any help would be appreciated. I have disc brakes in the front and drums in the back My jeep does not pull to any side when I mash the brakes just stiff as hell Thank you.
Jsdtm is offline
post #2 of 8 Old 08-13-2013, 09:37 PM
walkerhoundvm
1981 CJ8
Welcome to the forum!! I'd be wondering if it just isn't a normal CJ braking system - you have manual brakes so it's not unheard of to have to press pretty dang hard to come to a complete stop.
To rule it out, you'll probably have to take a closer look at your brakes - everything from the pads to the rotor to the calipers. If all of that looks to be in good order, next step is to bleed the brakes, starting from those furthest from the MC (passenger rear) to those closest (drivers front) to make sure there aren't any air bubbles in the lines. Obviously make sure there's enough brake fluid in the MC. After that I'd worry about your master cylinder, unless there's obvious signs of leaking around the firewall mount.
walkerhoundvm is offline
post #3 of 8 Old 08-14-2013, 05:29 AM Thread Starter
Jsdtm
Ok thanks for the help. I will check all these out and post back. Thanks again!
Jsdtm is offline
post #4 of 8 Old 08-14-2013, 07:24 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
another quick question is what size tires are you running? Bigger tires/wheels will slow the whole procedure down.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #5 of 8 Old 08-14-2013, 07:40 AM
WindKnot
1977 CJ7
Has it been awhile since you've driven a vehicle without power brakes? Just about everything now days has them.
There is quite a difference between them. They CAN be converted.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #6 of 8 Old 08-14-2013, 07:50 AM
hotrod351
1955 M-38
agree, after bleeding and adjusting the brakes make sure you have the right master cylinder. i had a similar problem with a old bronco wrong MC made me really push down hard on the pedal to stop.
hotrod351 is offline
post #7 of 8 Old 08-14-2013, 03:00 PM Thread Starter
Jsdtm
I have 33x12.50r15s. I haven't ever driven a car without power breaks. The closest I've come is my 41 ford tractor and now that I think about it it's about the same. Haha. How do I know if the MC is the correct one? Doesn't look like I can get to working on it until the weekend. Darn Florida daily rain!
Jsdtm is offline
post #8 of 8 Old 08-20-2013, 07:07 PM Thread Starter
Jsdtm
Update: I bled the brakes and they are fine now. Thanks y'all
Jsdtm is offline
