steers TOO EASY, dangerous! help - Page 4 - JeepForum.com
post #46 of 49 Old 07-16-2013, 07:49 PM Thread Starter
TexasJeepyall
CJ5
Originally Posted by Tigerjeep79 View Post
If that were my Jeep I'd just take out the blocks and bolt it back together with new U-bolts. That will definitely improve the steering issue. Then if it's still a little spooky, I'd take it to an alignment shop. It's not expensive (all they can really do is toe-in), but you'd have the report that would show the caster angle. If under 6 degrees positive you can get some steel shims - I have 2 degree shims on my CJ7 - and bolt them to the spring pack using new bolts.
When all that is worked out, you can start spending REAL money on that 5. Fun stuff!
this made me feel so excited, you made my day buddy
TexasJeepyall is offline
post #47 of 49 Old 07-16-2013, 09:21 PM
Skerr
Research "high steer" before you go that route. It's not quite that simple. Very do-able, but a little cost to SOA to do it right.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #48 of 49 Old 08-13-2013, 11:59 PM
spottedfrog
1979 CJ5
I am thinking, based on the pix. that going SUA again would likly be cheaper/easier than fixin the SOA set up to be correct.
I think that the old owner just welded block on top, got longer shocks and drive shafts, added a drop pitman arm, and just left the rest.
scary stuff for sure.
If it were mine I'd take it back to SUA. and run 3-4" lift and 33's 35's are taxing on the stock axles, and a little out of proportion on a CJ5.
We DO need more pictures to really tell. We have to see how things are attached, what is still left to work with ect.
spottedfrog is offline
post #49 of 49 Old 08-14-2013, 12:04 AM Thread Starter
TexasJeepyall
CJ5
pics tomorrow bud, 33s sound ok to me
hey atheists,
If God doesn’t exist… then how has anyone really been far even as decided to use even go want to do look more like
http://www.hudl.com/athlete/662931/highlights/35184377
danger , power steering , power steering box , steering
