steers TOO EASY, dangerous! help - JeepForum.com
post #1 of 49 Old 07-07-2013, 02:56 PM Thread Starter
TexasJeepyall
CJ5
hey guys, my cj5 steers too easy! meaning i could nudge the steering wheel and it takes about a turn and a half without recovering. if i where to turn it and give it some gas, it'll stay that way even if i let go of the wheel. I really have no clue what it could be. maybe the powersteering box? it seems pretty dangerous to be driving around going 75 in it and having such a delicate handle. any help is appreciated.
TexasJeepyall is offline
post #2 of 49 Old 07-07-2013, 03:37 PM
only in a jeep cj
To help diagnose something like that we really need a little more info. Was an engine swap done where there was a more powerful steering pump or more fluid flow? Steering box swap to a variable ratio?
Is there a huge shackle lift or spring lift that changed the caster angle?
Also, for the not returning to center thing, I would check for stiff ball joints and binding linkages. Front jackstands with wheels off and disconnect at pitman arm. Cycle back and forth for resistance
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 49 Old 07-07-2013, 03:51 PM
LumpyGrits
Need to see some pictures to see all the mods done as lift etc
LG
LumpyGrits is offline
post #4 of 49 Old 07-07-2013, 05:30 PM
gmakra
I suspect your castor is way off take it to have the front end aligned and they will tell you what your castor is.
You will either need to cut and re-weld the spring perches or get shims to correct.
If you go the shim route get steel ones the aluminum wont hold up at all.
gmakra is offline
post #5 of 49 Old 07-07-2013, 05:32 PM
LumpyGrits
Toe-in can also be a big cause too.
LG
post #6 of 49 Old 07-08-2013, 08:48 AM
DougE
1983 CJ7
X2 Caster. You need about 6*.
1983 CJ7, 258I6, T4, Dana 300, 31x10.5x15 DuraTrac
DougE is online now
post #7 of 49 Old 07-08-2013, 11:49 AM
foggybottombob
I would guess that you either don't have enough positive caster or your steering arms on your knuckles are too long or your pitman arm is too short.
If you have a factory front axle then you have stock knuckles. It is not likely that your pitman arm was changed either. But you could easily have too little caster.
foggybottombob is offline
post #8 of 49 Old 07-08-2013, 09:25 PM Thread Starter
TexasJeepyall
CJ5
LG
ill have some pics up for you by monday!
post #9 of 49 Old 07-08-2013, 09:29 PM Thread Starter
TexasJeepyall
CJ5
yeah man after doing some research i think it may be the caster angle! i get my jeep back from my dad on monday, ill take some pics of it and show you
post #10 of 49 Old 07-08-2013, 09:30 PM Thread Starter
TexasJeepyall
CJ5
i think it might be the caster angle buddy
post #11 of 49 Old 07-09-2013, 07:37 AM
wellmax
Tex,
75 mph in a CJ5
I do not think you should ever drive 75 mph in a cj5, just my two cents!!!!!
but then what would I know: I am just a old fart that has lived a long time and driven a jeep for many years.
they are great vehicles for the woods, hills and other wild country.
but with the short wheel base and big tires, makes them a bit unstable at highway speeds.
good luck and be safe,
guess you have heard the other term used to describe a CJ5
"Widow Maker"
wellmax is offline
post #12 of 49 Old 07-09-2013, 07:43 AM
hotrod351
1955 M-38
toe in will correct a lot of problems. 75 MPH in a cj-5. not good but then i remember doing 80 MPH in my old 55 M38A1, did it once and never again, handled perfect but then it only take one little problem to go dead.
hotrod351 is offline
post #13 of 49 Old 07-09-2013, 07:53 AM
CSP
You guys asking for pictures to determine lift, caster, etc. must have some highly calibrated eyeballs.
The OP could actually just tell us if it has lift, how much, etc.
CSP is offline
post #14 of 49 Old 07-09-2013, 08:37 AM
KMD
1976 CJ7
This^^^^
Also need to know if it is a stock steering gear and pump?
Did it just happen out of the blue or after something was changed?
KMD is offline
post #15 of 49 Old 07-09-2013, 12:34 PM Thread Starter
TexasJeepyall
CJ5
Originally Posted by KMD View Post
This^^^^
thing is that its a handmedown from my old man thats been sitting in a garage for years and years. i dont know much about the jeep. i get it back on monday and maybe you guys could lend me a hand with this stuff!
danger , power steering , power steering box , steering
