Steerings too tight? - JeepForum.com
post #1 of 5 Old 01-19-2010, 08:52 AM Thread Starter
Jeaux
This is my first 1980 CJ5 258 with manual steering.
I just replaced the steering box and steering column linkage.
Took it down the street and when I turn corners it does not straighten out by it's self.
I have to turn it back the other way or in up in the ditch.
I have loosened the nut and backed out the allen screw all it goes and is still to tight.
Is this just the way they are?
Jeaux is offline
post #2 of 5 Old 01-19-2010, 10:37 AM Thread Starter
Jeaux
Not one person wants to chime in?
I wish I could delete this post?
Sorry if I posted a common question.
I did use the search feature and I did find another suggestion.
Thanks
Jeaux is offline
post #3 of 5 Old 01-19-2010, 12:13 PM
jeepcj258
1980 CJ5
Did you mess with the steering column at all?
If you over-tightened the nut, there is a chance you pressed something down that should not have been and is binding
jeepcj258 is offline
post #4 of 5 Old 01-19-2010, 02:03 PM
keith460
Jeep. There's Only One
keith460's Avatar
You should never adjust that allen screw with the locknut as this sets the drag torque adjustment when bench testing the gearbox for worm bearing preload setting.
A steering wheel that does not return to center after making a turn usually indicates either worn upper and lower ball joints or poor castor angle. The axle castor should be around 6 for CJ models.
1984 CJ-7 Renegade
keith460 is offline
post #5 of 5 Old 01-19-2010, 06:08 PM
Trailmix
1980 CJ5
Did it do it before you replaced the steering box? If so I would say you have a tight ball joint or possibly tight axle u-joint. You can jack the front wheels off the ground and disconnect one tie rod end and try turning each wheel back and forth by hand to isolate the problem. Good luck.
Trailmix is offline
Tight steering sean007r Jeep CJ Forum 7 09-29-2009 08:34 PM
Bestop Supertop WAY too tight? HELP!! xbarksdale Jeep CJ Forum 18 02-26-2009 02:49 PM
Tight Steering Anyone??? CJ7 pvtloewer Jeep CJ Forum 4 04-24-2008 12:36 PM
New U-Joints feels tight Wolf359 Jeep CJ Forum 3 10-25-2006 11:00 PM
money's tight. looking for help. wannahavefun Jeep CJ Forum 1 09-08-2006 02:27 PM
