Steering wheel issues....????? - JeepForum.com
post #1 of 5 Old 05-02-2010, 11:10 AM Thread Starter
breakthru
Okay, I can put both hands at 9 and 3 and push the steering wheel abou a 1/4 inch and it feels like it's spring loaded and comes back up once I remove the pressure... any idea what could be wrong? There is a small gap in my plastic on the column right behind the wheel now as well... not sure what happened or what needs fixing? Any advice is helpful. Thank you.
C
1985 CJ-7 258ci with a T5 tranny, Dana 300 t-case with Tera Low 4:1, 4" sagging Suspension lift, Warn floating axles, all around disc brakes, DUI Distributor, stainless brake lines, flexalite dual electric fan, weber carb, and 33 AT. Future mods include going to 35's under a Rubicon Express lift with full body replacement, interior restore and train horn... with time, money, and weather permitting.
breakthru is offline
post #2 of 5 Old 05-02-2010, 11:41 AM
Mike78cj7
1978 CJ7
I had alot of play in my column I can't remember if it moved in and out but it moved up and down. I had to replace my lower steering column bearing and it tightened everything up. Here's where I bought it. Original Replacement Parts 4486713 - Lower Steering Column Bearing for 76-95 Jeep® CJ-5, CJ-7, CJ-8 Scrambler & Wrangler YJ - Quadratec
Mike78cj7 is offline
post #3 of 5 Old 05-02-2010, 09:11 PM Thread Starter
breakthru
Thanks... I'll check that.
post #4 of 5 Old 05-03-2010, 08:49 AM
scrapman
Mike,
My bearing is out also, was it pretty easy to replace? Did you have to pull the steering column to replace?
Thanks
scrapman is offline
post #5 of 5 Old 05-03-2010, 06:26 PM Thread Starter
breakthru
I'm not sure... I'm still wondering if my spring loaded feeling is definitely a bearing gone bad??? Any help Jeepers?
How to straighten steering wheel after steering box install. SuperSportCJ Jeep CJ Forum 6 11-18-2009 01:57 PM
Replaced steering shaft-steering wheel 90 deg. out jshi218 Jeep CJ Forum 9 08-25-2009 07:39 PM
No Wheel/No Steal System for Grant Steering wheel Ridettu02 Jeep CJ Forum 12 11-11-2008 12:44 AM
Size of the nut for steering column to hold steering wheel supraman1990 Jeep CJ Forum 4 02-07-2008 06:16 PM
steering wheel issues kaibab Jeep CJ Forum 4 06-26-2006 03:26 PM
