Steering Wanders Badly. - JeepForum.com
post #1 of 14 Old 06-17-2007, 07:47 PM Thread Starter
JeepinYahoo
JeepinYahoo's Avatar
1977 CJ5
The steering on the CJ is really wandering badly. I am thinking it is the steering box going out because it feels like when that happened on my Ford and I can turn the wheel 1/3 around in both directions without the tires moving. I do not believe it is in the linkage but might be. I also have about 3" of lift without a drop pitman arm, could this cause wandering and unresponsive steering? Is there a way to check the steering box? Tighten it?
'77 CJ-5---'63 Scout 80 FOR SALE---'71 Scout 800B---'78 F-250 Camper Special---'75 Econoline 100
JeepinYahoo is offline
post #2 of 14 Old 06-17-2007, 07:53 PM
jadams68
jadams68's Avatar
Measure your castor angle on the front axle and shim the front axle if necessary to correct it.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 14 Old 06-17-2007, 08:11 PM Thread Starter
JeepinYahoo
1977 CJ5
How and how....sorry, TJ guy here. Us coil guys dont know what to do with the dag-gummed leaf springs. I do know about the shims, how do I measure castor and how do I find out which shims to get.
post #4 of 14 Old 06-17-2007, 08:32 PM
79cj7reny
1979 CJ7
You'll have to take it to an alignment shop. They'll tell you if your measurements are within acceptable range. They can install the correct shims. I would check ALL of your steering components first before messing with the caster. You say that you can turn the steering wheel a 1/3 turn before the wheels move. Is that while sitting still? If so then it's definitely a steering issue not a caster issue. As far as the pitman arm, I would think that if you need a dropped arm and are running stock arm, then you would feel the steering bind. Someone else should be able to shed some light on that. Good luck!
79cj7reny is offline
post #5 of 14 Old 06-17-2007, 09:13 PM
John N
1981 CJ8
You need someone, who knows what they're looking at, to inspect the condition of your steering system. It could be one or a combination of parts and steering isn't something to guess at. What you're describing is not the result of not having a drop pitman arm. It is probably the result of worn out, broken and/or loose parts.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #6 of 14 Old 06-17-2007, 09:22 PM
schwim
YES!
I just went through this exact thing. Turning the wheel was actually rotating the tierod about a 1/3 of a complete revolution before it would affect the steering in the least. Putting the draglink on the same plane as the tierod solved my problem completely.
thanks,
json
schwim is offline
post #7 of 14 Old 06-17-2007, 09:54 PM Thread Starter
JeepinYahoo
1977 CJ5
So many answers...I dont know what to choose. Well, I know it has to be from either the pitman arm or the steering box at this point. I doubt it is caster, I know it isnt the linkage, so I guess I will try the pitman arm first.
post #8 of 14 Old 06-17-2007, 09:59 PM Thread Starter
JeepinYahoo
1977 CJ5
Exactly what I thought.
post #9 of 14 Old 06-17-2007, 10:00 PM
kavephish
1981 CJ5
Why not go to an alignmet/mechanic shop and ask them to "look at it and give you a quote"....then fix it yourself.
kavephish is offline
post #10 of 14 Old 06-17-2007, 10:03 PM Thread Starter
JeepinYahoo
1977 CJ5
I might if I can't figure it out.
post #11 of 14 Old 06-18-2007, 05:25 AM
John Brereton
Check your steering box bracket. CJ steering brackets are known to be crap. Over time they loosen up, and break. Then, when you turn the steering wheel the steering box starts moving all around instead of turning the wheels.
Have someone turn the steering wheel while you sit in front of the Jeep and watch the steering box (or for any other odd movement).
What's left of a '79 CJ5
3 - 4" total lift
4.88 gears in a Dana 30 and off center ff Dana 44 with disc brakes
258 with TFI /T18 /D18 drive train with Saturn O.D.
33 x 12 DC Mud Country Radials
John Brereton is offline
post #12 of 14 Old 06-18-2007, 07:02 AM
Fatman
Fatman's Avatar
2008 CJ7
tie rod ends
steering box
steering rod
ball joints
shackle bushings
loose spring / axle u-bolts
These are primarily the things that can and will go bad causing the "wander" condition.
You should get it to an alignment shop and not guess at the problem.
Thread Links:
Fatman is offline
post #13 of 14 Old 06-18-2007, 07:14 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
All good suggestions above.. a good way to generally diagnose your steering system is to have someone jump in the Jeep and turn the wheel fully to the left and right several times while you inspect. Start with the hood open. Check the steering shaft for play/slop. Then, move down to the box itself. Make sure it's not moving around on the mount, check to see if there's any sort of delay between the steering shaft input and output which would indicate a worn box (internally). Check the steering joints starting at the end of the pitman arm and working your way down to the steering joints (tie rod ends) at the axle ends.. look for slop. Check your leaf spring mounts and shackle mounts for slop and movement (a little movement is unavoidable.. rocking back and forth a couple inches isn't). If all that checks out, put a jack under the axle and raise tires off the ground. Grab tires at 12'oclock and 6'oclock and wiggle tire to check for slop in the wheelbearings or balljoints. Those are pretty much the major contributing areas/causes of steering slop. If the steering is pretty tight but the vehicle wanders, then you probably have caster issues (not enough positive caster) which can be remedied with shims.
BESRK is offline
post #14 of 14 Old 06-18-2007, 01:55 PM
neilmuehlhausen
1979 CJ5
check the universal joinyt at the bottom of the steering shaft where iyt connects to the steering box. I had the same problem with my 79', replaced the shaft and attached u-joint, and now it drives like new.
neilmuehlhausen is offline
Why your steering wanders or seems loose. jadams68 Jeep CJ Forum 336 12-21-2014 03:17 PM
1978 cj7 wanders bad dennism1960 Jeep CJ Forum 4 08-18-2009 07:15 PM
CJ5 wanders all over road over 45 mph 76CJ5Levi Jeep CJ Forum 1 07-06-2009 10:00 AM
why steering wanders aero mech Jeep CJ Forum 2 08-28-2007 06:45 PM
Steering is loose, wanders back and forth sharkbait Jeep CJ Forum 1 05-08-2006 09:25 AM
