Steering upgrade in the works! advice needed - JeepForum.com
post #1 of 7 Old 08-26-2014, 01:12 PM Thread Starter
weapon
1983 CJ7
Decided to upgrade the steering. I have a new intermediate shaft and just picked up an H1 box to replace my original.
I already have a M.O.R.E. Steering Box Mounting Bracket installed.
What tools will I need to remove the pitman arm? Any other surprises that I might encounter on this journey? Any advice is welcome.
weapon is offline
post #2 of 7 Old 08-26-2014, 01:18 PM
CSP
A pitman arm puller will be needed.
At the risk of sounding like a broken record weapon, there are lots of threads on the pitfalls of removing pitman arms and methods to get by them.
CSP is offline
post #3 of 7 Old 08-26-2014, 02:43 PM Thread Starter
weapon
1983 CJ7
Sorry I should have stated that better. I knew that I needed a puller after I posted it (plan on hitting up HF after work).
Was not only looking for specifics on the puller. What I am more interested in is any surprises I can expect. For Ex. Getting the shaft to release from the box, any issues with the H1 box and the bracket, clearance issues with the frame.
I will probably pull the steering column so I can rebuild that also.
weapon is offline
post #4 of 7 Old 08-26-2014, 03:29 PM
Jeepcj30
1966 CJ5
Penetrating oil and heat. Lots of heat. I had a rebuilt box to replace mine so wasn't worried when I cooked the seals out of the old one
Jeepcj30 is offline
post #5 of 7 Old 08-26-2014, 03:38 PM
CSP
Heat is fine if you don't plan on re-using the box, which is the case here.
It's bad for seals though if it's a pitman arm swap.
CSP is offline
post #6 of 7 Old 08-26-2014, 10:30 PM
dg6772
Replacing the parts. ...cut midshaft in half......all done.....saving for someone else.....as said oil,2-3 days prior, heat....
Dave in Muskegon using JeepForum
dg6772 is offline
post #7 of 7 Old 08-27-2014, 05:25 AM
grasmo
1982 CJ5
this works very well if you wanted to save anything:
https://www.kimballmidwest.com/Catal...6.628.358.2638
most of the time I haven't needed it. get the puller fixed and put as much pressure as you can, put some cardboard on the floor under the arm, put a little heat, and watch it shoot off like a bullet. don't be under it when you touch it with the heat. it will kill you.
grasmo is offline
