Steering Stabilizer mount question. - JeepForum.com
post #1 of 8 Old 08-01-2009, 04:56 PM Thread Starter
hh65flyer
I just installed a single-shock steering stabilizer on the CJ7 this afternoon.
Does anyone have an opinion on whether or not it matters if the stabilizer is installed above or below the tie-rod?
With the stabilizer in the 'normal' below the tie-rod position, it tends to rub the diff. I tried several positions with essentially the same results.
With the stabilizer 'flipped-over', on top of the tie-rod, there is no interference and it looks like I have more protection/clearance with it in that position also. Win-win right? Thanks.
1984 CJ7, 2nd owner.
360 V-8, T-176 and Dana 300.
D30/D44...Aussie/Lock-Rite
33" BFG Mud-Terrains, 1/2" shackle, 2" spring lift.
Vehicle weight reduction program: Rust!
hh65flyer is offline
post #2 of 8 Old 08-01-2009, 05:01 PM
a2tripp
1993 XJ Cherokee
mines on top, no problems here
93 cheromanche
a2tripp is offline
post #3 of 8 Old 08-01-2009, 05:33 PM
CJ Chet
Flip your tie rod. Works great!
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #4 of 8 Old 08-01-2009, 07:13 PM
26679cj5
do you mind if i butt in and ask which you guys prefer, the stabilizer that has a bracket between the spring and perch like pictured above or the style that just clamps on to the axle tube. i have access to both for my rebuild and have been wondering which is better.
26679cj5 is offline
post #5 of 8 Old 08-01-2009, 09:54 PM
86JeepCJ7
I do not know from experience which one is better, but my rancho single is u bolted to the axle tube - seem solid to me.
86JeepCJ7 is offline
post #6 of 8 Old 08-02-2009, 10:21 AM Thread Starter
hh65flyer
CJ Chet, thanks for the tip. I'm going to give it a try.
26679cj5...judging by CJ Chet's photo, the mount that is between the spring and perch seems to allow for a more parallel installation and possibly less interference with the tie rod and diff.
There are tons of discussions regarding the merits of the stab at all so you may want to read up on those before deciding. I just swapped axles a while ago and the old stabilizer was trashed. I got a pretty good deal on one and re-installed it with the swap. I probably didn't even need it.
Hope that helps.
post #7 of 8 Old 08-04-2009, 07:09 PM
26679cj5
oh yeah,dont even consider a dual stabilizer kit like the one offered by 4wd.com. the dual shocks are harder than hell to fit without rubbing and the bottom one hangs below the axle tube so you end up destroying it the first time you go offroad.
26679cj5 is offline
post #8 of 8 Old 08-05-2009, 06:33 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
after i folded mine by hitting it on a rock i reversed it, big u bolt at the pumpkin and the small twins out toward the tie rod end. This allows me to run them on top of the tube. It then exposes a weak tie rod but hey, havn't done the TRF yet.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
transmission stabilizer mount wmsthree Jeep CJ Forum 13 12-04-2015 05:14 AM
Rancho Steering Stabilizer Question ggerdsen Jeep CJ Forum 3 02-11-2009 02:28 PM
Another Rancho Steering Stabilizer Question. BioTex Jeep CJ Forum 0 02-11-2009 01:27 PM
Where to get a Stabilizer Mount? MuddyMules Jeep CJ Forum 10 01-25-2008 09:30 PM
Steering Stabilizer question bowlsy23 Jeep CJ Forum 1 02-23-2004 07:15 AM
