steering stabilizer - JeepForum.com
post #1 of 4 Old 07-10-2007, 12:12 PM Thread Starter
atomicflatulenc
steering stabilizer
Mines been hit by a few too many rocks. Seems to be working, but I'm having issues staying in a lane at 50mph, so I think its gonna get replaced, along with shackles and tires.
Is the double stabilizer worth it? pros and cons...
If a single, which one? I've got 4" of lift and 33 M/ts, might go back to 35" swampers.
'85 CJ7, 258 4.2 Howell TBI, NP435, twin sticked Dana300, 4.56 Yukon chromoly: Rear20-extra thick tubes, shaved,trussed,discbrakes,ARB: Front30- flipped tierod,Detroit EZ locker, warn hubs: 3.5" BDS YJ springs and booster, 35" Trxus M/T's, rhino'd, full roll cage, borgenson steering shaft, big daddy steering box bracket...Unknown OIL Leak(working on it...)
FOR SALE $6000
atomicflatulenc is offline
post #2 of 4 Old 07-10-2007, 12:27 PM
gosupes
The stabilizer will have no effect on how the vehicle tracks down the highway. Get the tires replaced and have the alignment checked, change shackles or bushings, then see how it tracks down the road.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #3 of 4 Old 07-10-2007, 01:08 PM
JoonHoss
2011 JK Wrangler
^^^ what Supes said
a stabilizer will only lessen the feel of actual problems, not correct them.
not that they are bad to have, but they should be the last thing you check.
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #4 of 4 Old 07-10-2007, 01:17 PM
79cj7reny
1979 CJ7
I agree. Your wandering is likely something else. Check the following in no particular order: Wheel bearings, tie rod ends, ball joints, steering box play, steering box mounting points, steering shaft.
79cj7reny is offline
What Steering Stabilizer? Strings72 Jeep CJ Forum 9 11-01-2009 03:56 PM
steering stabilizer fit? blackhawk099 Jeep CJ Forum 2 07-13-2009 12:16 AM
Steering Stabilizer TX JEEP CJ7 Jeep CJ Forum 2 02-16-2009 07:55 AM
Which Steering Stabilizer for 67 CJ5? acoustic Jeep CJ Forum 3 11-08-2008 06:20 AM
Steering Stabilizer pf1130 Jeep CJ Forum 9 12-11-2004 10:11 PM
