steering stabilizer - JeepForum.com
post #1 of 7 Old 05-08-2006, 11:52 AM Thread Starter
tacodruff
steering stabilizer
am i supposed to mount the shock half compressed or completely decompressed. im talking about the steering shock that sits just in front of the front differential
tacodruff is offline
post #2 of 7 Old 05-08-2006, 12:28 PM
jeepskate
With everything sitting straight, about half compressed. Think about it and it'll make perfect sense.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 7 Old 05-08-2006, 12:31 PM Thread Starter
tacodruff
if its half compressed, would that push my steering to one side? but if its decompressed id only get damper one way. i dont know...but thanks for the reply
post #4 of 7 Old 05-08-2006, 02:54 PM
jeepskate
A shock isn't strong enough to push your steering to the side, especially one valved for use as a steering stabilizer. If you mount it compressed, you'll only be able to steering in one direction...think about it...
post #5 of 7 Old 05-08-2006, 06:17 PM
CJ Fanatic
CJ Fanatic's Avatar
You want to make sure to use a damper(shock) intended for a steering stabilizer. It has no tendency to push or pull in either direction. A shock absorber is usually charged with some sort of gas, usually nitrogen, and will push to full extension. A steering stabilizer will be neutral at any given position within the stroke. So, as mentioned by jeepskate, mount it half way in it's travel, half compressed.
A closed mouth gains no foot.
1977 CJ5, '75 258, Motorcraft 2150 carb, HEI dizzy, BDS 2.5" suspension, 3/4" Daystar Rock Krusher Greasable shackles, M.O.R.E. steering brace, Flaming River steering shaft, Tie rod flip, Yukon AMC20 axle kit, 1.5" Trail Sport wheel spacers, 15x10" Black Cragar soft 8s w/ 33" Yokohama Geolander MTs, Goodridge SS brake lines, Classic Tube stainless hard lines, YJ power brake with front disc upgrade (had 4 wheel drums)
CJ Fanatic is offline
post #6 of 7 Old 05-08-2006, 08:06 PM
fyr196
fyr196's Avatar
I have a 1980 CJ7. I just had the all steering components replaced from the steering box to the knuckles. (Due to a bad SOA lift from the PO) I get some scary bump steer at high speeds, about 50 mph and up. Would a steering stabilizer help? I have 33" tires with a 2" lift. Does anyone know of a good stabilizer to go with, if it is worth it?
Thanks
fyr196 is offline
post #7 of 7 Old 05-08-2006, 09:28 PM
jeepskate
Steering stabilizer isn't a cure for bad steering...you need to make sure everything else with your front end is right...shackles, shackle bushings, caster, ball joints, axle u-joints, steering box mount...
What Steering Stabilizer? Strings72 Jeep CJ Forum 9 11-01-2009 03:56 PM
steering stabilizer fit? blackhawk099 Jeep CJ Forum 2 07-13-2009 12:16 AM
Steering Stabilizer TX JEEP CJ7 Jeep CJ Forum 2 02-16-2009 07:55 AM
Which Steering Stabilizer for 67 CJ5? acoustic Jeep CJ Forum 3 11-08-2008 06:20 AM
Steering Stabilizer pf1130 Jeep CJ Forum 9 12-11-2004 10:11 PM
