Steering shaft U-joint part??? - JeepForum.com
post #1 of 14 Old 04-07-2008, 07:43 PM Thread Starter
SuB8HaVeN
Hey guys, I've replaced just about every steering component minus the steering box itself and the steering shaft, and it is still a little loose. I know the sticky mentioned replacing the steering shaft, but I'd like to keep it simple if at all possible. I had a friend tell me there is a U-joint in the steering and if you replace it, it should get rid of the loose steering. Does anyone know the specific part name of the coupling or U-joint that would be worn out on the steering shaft? I see a steering bearing and a part that attaches the steering shaft to the steering box, but I'm not sure what I need to order.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #2 of 14 Old 04-07-2008, 08:05 PM
illinicj
1979 CJ7
I have seen talk on a web forum that there's a guy on ebay selling the u joint for the shaft.
illinicj is offline
post #3 of 14 Old 04-07-2008, 10:44 PM
peanutfarmer101
1978 CJ7
I think they call it a rag joint...at the bottom of shaft where it attaches to the box .....I think it is several pieces....Borgenson makes a really strong shaft with u-joints that I like better..it was money well spent
Peanutfarmer101
'78 CJ-7..304 T400.. 30 up front, locked 20 in back(1 piece axles)..Quadratrac w/ parttime conversion..4" lift w/Currie greasable shackles..33" AT's on 15x12 alum wheels
peanutfarmer101 is offline
post #4 of 14 Old 04-08-2008, 09:58 AM Thread Starter
SuB8HaVeN
Well, I checked the steering today and sitting still, you can move the steering wheel about 1-2" without the wheels turning at all. I looked under the hood while turning the wheel and you can see there doesn't look to be any play in the steering shaft as it is all moving all the way to the power steering gear box. Does this mean I need to adjust the preload on the gear box?
post #5 of 14 Old 04-08-2008, 10:13 AM
Mike Romain
No, you should adjust the 'adjuster plug' on the steering box.
This takes up the right to left play. The adjuster plug on the Saganaw box is in the end the shaft goes in. You are supposed to loosen off the large locknut, then tighten the center plug all the way and back it off about 1/4" to 1/2" until the play is 'just' gone, then tighten back up that lock nut. A pair of pump plier (channel locks) works on that large lock nut and a center punch in the holes works to move the plug. A tool like an angle grinder wheel nut removal tool with it's two pins is used to turn the plug, but a hammer and punch will do...
Mike
Mike Romain is offline
post #6 of 14 Old 04-08-2008, 10:17 AM Thread Starter
SuB8HaVeN
Sounds good, thanks for the info. Do I have to take the lower boot off, etc to get to the locknut and center plug? I'm just wondering if I should order the lower boot kit from Quadratec to replace it while it's apart.
post #7 of 14 Old 04-08-2008, 10:49 AM
tsjeepcj
1981 CJ7
here's a nice article that references the adjustment on the last page of the article. i used it for reference when I drilled and tapped mine for hydro assist.
http://www.pavementsucks.com/tech/steeringbox.php
81 cj7 on 37's...
tsjeepcj is offline
post #8 of 14 Old 04-08-2008, 11:12 AM
Mike Romain
No, but it is a tight fit around the bottom of the rad.
I have the rebuild sheet in PDF for the TJ box which is pretty much identical to the CJ one if you would like it. It has all the pre-loads and adjustments.
Mike
post #9 of 14 Old 04-08-2008, 11:21 AM Thread Starter
SuB8HaVeN
I have the Chilton's with an exploded view so that should do. It doesn't go into the detail on the procedure but it has a few pictures that should help.
post #10 of 14 Old 04-08-2008, 11:51 AM
Face
I'd love to get my hands on the details behind rebuilding a CJ box (even if it has TJ in the title ). Could you forward this .pdf to me, Mike? I can shoot you my email address in a PM if necessary.
My box just started leaking after a rock-heavy off-road trip. 23 yr old seals don't like rocks and high pressure.
How much do "new" steering boxes cost? Is it worth rebuilding or just replacing with a stronger one?
Face is offline
post #11 of 14 Old 04-08-2008, 12:02 PM
Mike Romain
Send me your email.
The CJ box is the strong one according to the rebuild shop I was at. It has the nice 1 piece adjuster plug that typically lasts, unlike the 2 piece TJ one. My friend with the leaky TJ one even got the CJ parts to 'upgrade' his.
Mike
post #12 of 14 Old 04-08-2008, 01:51 PM Thread Starter
SuB8HaVeN
The link mentioned in post # 7 goes into detail about rebuilding the gear box. It may help to take a look at that.
post #13 of 14 Old 04-08-2008, 01:55 PM
tsjeepcj
1981 CJ7
i went with a j20 box when i did my hydro assist, iirc it moves more fluid than the cj7 box. may be something you want to think about if ur trying to turn bigger tires...
81 cj7 on 37's...
tsjeepcj is offline
post #14 of 14 Old 04-08-2008, 02:10 PM
Mike Romain
I browsed through that, but didn't find any adjustment specs.
In my opinion building a box by 'feel' is a bad waste of time. There are inch pound specs for the bearing preloads and other setting that should be 'proper'.
Mike
Steering Shaft U-Joint Picture - Help ggerdsen Jeep CJ Forum 3 02-26-2009 12:53 PM
Axle shaft U joint replacement HELP! xj89 Jeep CJ Forum 25 11-14-2007 07:53 AM
Question about the lower joint on my steering shaft T-$$ Jeep CJ Forum 2 01-10-2007 03:33 AM
80 CJ7 Steering Shaft Upper Bearing... part #?? nickdz Jeep CJ Forum 1 12-20-2006 06:17 PM
Where can I get a new steering shaft joint?? '83Laredo Jeep CJ Forum 4 05-16-2005 10:28 AM
