Steering shaft? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Steering shaft?
TERAFLEX JK Speed bump kit AND limiting strap kit!! AT ROCRuffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread Today, 11:37 AM   #1
Austin9504
Steering shaft?
Taking the old gearbox out today, got the lines undone, clamp on the end of the shaft undone. But it appears to be seized up? Any suggestions? I've got it soaking in WD 40, will go back and check on it in a few hours... Any and all help is appreciated!
Also, suggestions on getting the pitman arm off of what appears to be the tie rod end??? Not sure on that one. But need some advice on that one too
Austin9504 is offline   Reply With Quote Quick reply to this message
Unread Today, 05:58 PM   #2
redfin188t
1982 CJ7
I've been going through this painful process for the past week. Loosen/remove the bolt on the bell housing and pry it back with a large screw driver, should slide back enough to remove it from the gear box. You'll need a tie rod puller to remove the end tie rod from the pitman arm. Good luck.
redfin188t is offline   Reply With Quote Quick reply to this message
Unread Today, 06:37 PM   #3
CSP
Bellcoupler not bellhousing.
CSP is online now   Reply With Quote Quick reply to this message
Unread Today, 06:43 PM   #4
Austin9504
That's the thing. Is the shaft supposed to move? I know on GM vehicles, the the intermediate shaft slides so you can pull it out
