Steering shaft - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Steering shaft
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 04-10-2014, 06:51 PM   #1
Spieg8
1984 CJ8
Looking for a new steering shaft
Anyone have experience with Crown HD steering shaft?
http://www.amazon.com/gp/product/B00...A3CM4NUYDVGV5D
My old shaft is pretty worn out and I'm looking for a better than stock replacement, but don't want to fork over the big bux for Borgeson. I know that Crown parts are not known for quality, but this looks like it may be good enough for my purposes (if it fits correctly).
Spieg8 is offline   Reply With Quote
Unread 04-10-2014, 07:37 PM   #2
4milechuck
Junior Member
1983 CJ8
Well I can say that mine lasted about 6 months. I did the bearings (up by firewall) also & the whole thing rattles as if it has been in there years. Now have Borgeson ready to install & the visible difference is remarkable. Heavier materials & machined quality. I wish I had spent the money up front & not gone through replacing these parts twice in one year.
4milechuck is offline   Reply With Quote
Unread 04-11-2014, 05:00 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I was in at a local steering and suspension shop getting a seal for the steering box and they mentioned to me that the will rebuild my shaft with greasable heavy duty u-joints. If mine went bad, I would likely go that route.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 04-11-2014, 05:34 AM   #4
Knucklehead
1973 CJ5
Don't waste your $$ on a stock-type replacement, get the Borgeson.
Ty
'45 Ford GPW; '73 CJ5, 350/NP435/D20 w/Terlow gears, locked D30/D44; '13 CJ8, 304/T150/D20/D30/AMC20 w/locker and limited slip (T18 and Teralow gears in future); '88 Dodge RC, 360/NP435/NP205/D60s
Knucklehead is offline   Reply With Quote
Unread 04-11-2014, 06:21 AM   #5
bptactical
Building a steering shaft isn't rocket surgery. Go to Speedway.com and look in their racing section. You can get heavy duty double D sections and heavy duty u joints for a fraction of the Borgeson.
Even if you have to pay somebody to weld it up your still way ahead.
bptactical is offline   Reply With Quote
Unread 04-11-2014, 10:05 AM   #6
CJ5_Fan
1980 CJ5
I replaced my shaft with that one about 3 months ago due to knuckle wear on the original creating play in my steering. The shaft went in fine but I ended up using the original cinch collar as it fit better then theirs. It hasnt given me any cause for concern and seems to handle my power steering and 33x12.5 tires with not issues, and If I recall, the other option being discussed requires a mod to work and I didnt want to mess with that.
1980 CJ5 Renegade with 304 v8
Click HERE to check out my CJ5 restoration project page
CJ5_Fan is offline   Reply With Quote
Unread 04-11-2014, 08:19 PM   #7
ASteve
ASteve's Avatar
1972 CJ5
X2...http://www.jeepforum.com/forum/f8/da...l#post14584273
SC
http://www.astevecali.com
ASteve is offline   Reply With Quote
Unread 04-12-2014, 06:50 PM   #8
Cutlass327
Cutlass327's Avatar
1978 CJ5
Hmm.. I'll be finding out in a couple weeks. I just ordered one along with my lift parts. Gotta be better than what is in there now, and as long as I can find u-joints, I can replace those...
Rick
1978 CJ5 258/T177/D300, '86 D30/D44 WT axles, 'glass tub windshield frame, and fenders, 31x10.5 BFG A/T, TDK galv'd frame - DD and weekend toy
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote
