Steering question - JeepForum.com
post #1 of 4 Old 06-10-2002, 06:01 PM Thread Starter
benny6
Question Steering question
I have a 61 M38A1 with a Dana 30 front end and a GM Saginaw steering box (no power steering) I want to rebuild the steering system. Do all early model jeeps have the same steering rods and rod ends? What suggestions do you all have. My steering is really sloppy right now.
Thanks, benny6.
benny6 is offline
post #2 of 4 Old 06-10-2002, 10:39 PM
Hippo393
Cool
Welcome aboard, benny6. Either you or a pvs. owner must have really spent some $$ in beefing up that '61 to have a Dana 30 and Saginaw steering. Sounds like you've got a gem of a Jeep! Photos?
Saginaw steering was introduced on the CJ5 in '72, so that eliminates pre-72 linkage. Different links, joints, etc. I don't believe that any linkage is interchangable with the B.S. ("Before Saginaw") Ross steering. It's a good thing, though, because you're more likely to find parts for your getup. Let us know if you need resources!
-alan
Hippo393 is offline
post #3 of 4 Old 06-11-2002, 01:22 AM Thread Starter
benny6
Post
The jeep was my dads. His body doesn't allow him to do the things he used to. The jeep has been sitting for about 10 years. I convinced him to let me bring it back from the dead. The steering box is is bolted to a 1/2" steel plate that has been welded to the frame. It has an early 70's 350 with a 327 intake manifold, 327 heads, ram head exhaust, glass packs and a Rochester Quadra-jet off of a 425 Cadillac engine. I's got some floor board rust, but the multi-colored body is in good shape and needs a little rattle can action. I have a little problem with the suspension though. It still has stock leafs with a 2" shackle lift in the front. I have grind marks on the top of the front axle from the bottom of the crank pulley!!!! The axle is still on the top of the leafs. I recently put in a Ron Davis racing radiator, but still need to find a good set of low-profile dual fans. My biggest concerns right now is the tranny and steering. Once it's road worthy, I'll use it every day.
Have a good one! benny6.
benny6 is offline
post #4 of 4 Old 06-11-2002, 10:12 AM
Doug76CJ5
Post
Hey Benny! I would suggest getting rid of the 2" shackle lift and at most use 1/2" shackle lift as these come in heavy duty. The 2"ers will make the driving very unstable the jeep will tend to dip and dive so to speak, I think I would replace those prior to doing anything else and see if it helps.
76 CJ5 304 Bored .030 over- 4" trail master lift- 2" body lift- 1" shackle lift- 35x12.5 Mud King- Pwr steering conv- Herc'd tub, SuperTop by Bestop-lots more coming!
81 CJ7 totally stock- newest project!!
Doug76CJ5 is offline
Another CJ Steering question JackN77CJ7 Jeep CJ Forum 7 03-05-2007 07:39 AM
Another steering Question... Blue83CJ7 Jeep CJ Forum 2 09-29-2006 04:41 AM
steering question surlysteve Jeep CJ Forum 1 10-27-2003 07:39 PM
steering question 2cjs Jeep CJ Forum 3 12-07-2002 12:49 PM
cj-7 steering question Gemelos Jeep CJ Forum 10 04-12-2002 10:48 AM
