steering problems - JeepForum.com
post #1 of 8 Old 05-13-2003, 01:23 PM Thread Starter
Marc CJ7
steering problems
Lately when i would drive the CJ there was a wobble in the steering wheel. Not like loose steering but more like the wheels were wobbling and making the steering wheel move back and forth.
This weekend it got way worse. I was driving down my street and all of a sudden the steering got REAL touchy. and it started wobbling like crazy. To the point where I can't even drive it on the road cause it won't go into a straight line. If I make a tight turn either left or right the problem goes away for a short time (like 1 minute) but then it comes back again.
I looked at all the steering parts while it was parked but I didn't see anything that looked out of the ordinary. The on;y way I think I will be able to tell is if someone drives it and I look underneath while its moving.
Does anyone have any ideas where to start. I recently greased all my nipples (like 1,500 miles ago) that I could find and my tires aren't out of alignment... help
82 CJ7 - 304 / T5
98 GTI VR6
All Motor: 1.89 - 13.55 @ 101.60
Marc CJ7 is offline
post #2 of 8 Old 05-13-2003, 01:55 PM
MudLover
MudLover's Avatar
Check your hubs. Make sure they aren't locked up. That'd be the first place I'd look. Another other posibility is the joint in your steering shaft is going/gone bad. Other that that, I can't think of anything obvious at the moment. Perhaps your steering pump's gone bad? Maybe it's sending to much fluid at the wrong times make it steer without being told to? Check your steering box too, those have a habit (or so I'm told) of going bad.
Good Luck,
Marc
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
Red Jeep Club Member #2
MudLover is offline
post #3 of 8 Old 05-13-2003, 03:43 PM
tgc79cj5
You might want to make sure that all of your wheel lug bolts are good and tight.
I did some work on my brakes a few weeks ago and a couple of days later I had some real steering problems....turns out that I had not tightened my lugs enough and one of the rear wheels was loose. Lesson learned!
Good luck!
1979 CJ5
304 V8
T150 3 speed
Dana 30 Front
AMC 20 Rear
Dana 20 Xfer
BFG ATs 33x12.50
New Bestop Seats
tgc79cj5 is offline
post #4 of 8 Old 05-13-2003, 03:49 PM Thread Starter
Marc CJ7
Yeah, one of the first things I checked was the PS fluid resivor and the lugs... both are normal. I am thinking its something to do with the pump because it only happenes occoasionally when I make very sharp turns...
anyone else have any ideas?
82 CJ7 - 304 / T5
98 GTI VR6
Marc CJ7 is offline
post #5 of 8 Old 05-13-2003, 08:57 PM
only in a jeep cj
You can confirm the pump by removing the PS belt and driving it around the block (or in your case, a straight line) and see if it still happenes....
Could also be worn ball joints, bad tie rod ends, front axle U- Joints binding, loose steering box, or your Jeep just wanting attention.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #6 of 8 Old 05-13-2003, 11:37 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
I'm with OIAJC (the last post), but also check the your spring U-bolts. They can and do come loose (unless you are doing a spring swap !@#$%), and the effects of this are really weird and unpredicable.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #7 of 8 Old 05-14-2003, 12:16 AM
Jeep Daddy
Jeep Daddy's Avatar
Tell us more about your rig. Does it have a lift kit on it? How long are the shackles? What size and kind of tires?
I've read a lot of posts about "Death Wobble". That is what this sounds like. This is usually caused by long shackles and not enough caster in the front end alignment. Other causes are worn front end parts, worn wheel bearings, loose lugs, bad tires, steering and alignment. The usual problem is alignment caused by lifting the body/suspension imporperly. The problem is often masked by use of steering damper. If you get a new steering damper the problem will probably go away, but that really only masks the problem which should be addressed.
Good luck.
PS - do a search on "death wobble" for more input. This is very common.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #8 of 8 Old 05-16-2003, 12:01 PM Thread Starter
Marc CJ7
Thumbs up
thanks for all the tips, I am going to go home this weekend and give it the once over.
I will post my results.
82 CJ7 - 304 / T5
98 GTI VR6
Marc CJ7 is offline
steering problems hofmen Jeep CJ Forum 2 03-10-2007 01:13 PM
Steering Problems Charles Patters Jeep CJ Forum 4 01-12-2007 01:09 AM
Steering Problems wqrt Jeep CJ Forum 1 04-09-2006 07:06 PM
steering problems floatingboy Jeep CJ Forum 5 11-07-2005 02:05 PM
steering problems wiggs Jeep CJ Forum 3 05-28-2003 07:41 PM
